si pistons in b18c5
Old Apr 28, 2003 | 03:48 PM
514_type R's Avatar
Default si pistons in b18c5
I checked it out on the c-speed compression calculator and an other CR calculator and both had different result:
The pistons are usdm 2000 si .25 over bore and my head was ported and received a 15 thousand mill, which is abour the CR I would get with a 2 layer head gasket(id be still using oem 3 layer gasket. What will be my compression....
c-speed calculator says 11.7 and the other says 11.3
which one do you think is more accurate.
Will I notice a difference with the si pistons??
thanks
Old Apr 28, 2003 | 04:06 PM
non-VTEC's Avatar
Default Re: si pistons in b18c5 (514_type R)
why with si pistons.
go for CTR pistons instead. if your gonna tear the engine down to put in new pistons for a .3 or .4 increase in CR then dont bother.
Old Apr 28, 2003 | 04:08 PM
Type-R Yo!'s Avatar
New User
I'll go with the CTR pistons over the Si.
Old Apr 28, 2003 | 04:32 PM
Rob Dizzle's Avatar
Default Re: si pistons in b18c5 (Type-R Yo!)
si pistons wont work with b18xx rods
you need ctr pistons if you want the CR ratio of Si pistons
Old Apr 28, 2003 | 04:34 PM
GokuSSJ4's Avatar
Default Re: si pistons in b18c5 (Bob-DC2)
besides the CTR pistons are much better then SI
Old Apr 28, 2003 | 05:53 PM
MK Ultra's Avatar
Stock bore USDM B16A pistons should yield ~11.3:1 CR with a stock headgasket. 11.7:1 is probably closer to what you would get with the engine you describe.
I may be wrong about this, but I am reasonably sure that you can use B16A pistons in a B18C even though the wristpin end of the B18C rod is more narrow. I guess I'll find out for sure this summer since I intend to use JDM B16A pistons in my new bottom end.
CTR pistons yield around 12.3:1 with everything else stock, which is more than I'm comfortable with, especially since I'll be using stock cams.
Old Apr 28, 2003 | 07:41 PM
sbigblack02's Avatar
Default Re: si pistons in b18c5 (MK Ultra)
yeah buddy there is no point of putting si pistons in a type r your just hurting your self just get ctr pistons if your going to do that
Old Apr 29, 2003 | 12:33 PM
All-MotorSports's Avatar
Default Re: si pistons in b18c5 (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">why with si pistons.
go for CTR pistons instead. if your gonna tear the engine down to put in new pistons for a .3 or .4 increase in CR then dont bother.</TD></TR></TABLE>
It should be a 0.7-1.1 increase in compression if it'll be between 11.3-11.7 w/ the Si pistons. Sounds like a good daily driver compression to me, especially if it's close to 11.7.
Old Apr 29, 2003 | 12:44 PM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">si pistons wont work with b18xx rods
Where do you get your information? Totally incorrect.
you need ctr pistons if you want the CR ratio of Si pistons</TD></TR></TABLE>
wtf.....
Old Apr 29, 2003 | 12:55 PM
514_type R's Avatar
Default Re: si pistons in b18c5 (sgT)
thanks for the info, but 12.3 is way to high CR for me.... We get 94 octane gas but in reality its like 92, so I wont go over 11.7 or so, or else I will ahev to retard timing
I dont want to upgrade my ecu to hondata so the only fuel mods will be tuning with fpr and v-afc. If i put CTR pistons and the car pings, I wont have any other option then using hondata, swap for od1, harness etc...
So are the SI pistons bolt ons, are they worth it???
Old May 1, 2003 | 10:22 PM
514_type R's Avatar
last opinion b4 going to the garage
Old May 1, 2003 | 10:30 PM
MK Ultra's Avatar
Well, with good tuning you can run 12.3:1 on pump gas. Plenty of people do.
But I understand not being comfortable with it. I'm actually planning on doing the same thing for the same reason. Good luck.
Old May 2, 2003 | 12:05 AM
RICHJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 514_type R &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info, but 12.3 is way to high CR for me.... We get 94 octane gas but in reality its like 92, so I wont go over 11.7 or so, or else I will ahev to retard timing
So are the SI pistons bolt ons, are they worth it???</TD></TR></TABLE>
Why not use the CTR pistons (which fit the ITR rods for definate because I saw them on my rods yesterday ), and run a thicker gasket to lower the compression, TODA make some I'm sure there's some out there for turbo applications that may lower the CR enough for what you want (use a compression calculator to find the thickness you need).
Anyone see a problem with going this route?
Old May 2, 2003 | 09:52 AM
514_type R's Avatar
Default Re: si pistons in b18c5 (RICHJ)
well, I know for a fact that the si pistons fit with the type r rod, so there wont be a problem. I might have them coated for more reliability. And I dont really need more then 11.7 cr since im not planning on runnig high lift cams(max skunk stage 1)
Old May 2, 2003 | 10:00 AM
NSX Bob's Avatar
New User
I run CTR's on ITR rods and use 93 octane. Good tuning w/ the hondata and I have yet to have 1 instance of detonation. I just don't jump on the throttle at low rpms and it's fine. Go CTR's, you'll be happy later, IMO.
Old May 2, 2003 | 10:02 AM
OBDI JEDI's Avatar
Default Re: si pistons in b18c5 (Type R Bob)
whats the link to the CR calculator again?
Old May 2, 2003 | 10:19 AM
514_type R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R Bob &raquo;</TD></TR><TR><TD CLASS="quote">I run CTR's on ITR rods and use 93 octane. Good tuning w/ the hondata and I have yet to have 1 instance of detonation. I just don't jump on the throttle at low rpms and it's fine. Go CTR's, you'll be happy later, IMO.</TD></TR></TABLE>
I agree with you but I dont want to buy hondata, and switch to obd1. Have anyone experienced the si piston in b18c5?
Old May 2, 2003 | 10:20 AM
514_type R's Avatar
the only way id put hondata a¸nd CTR piston is if I eventually put jun 3 cams in the car.
Will 11.7 cr support jun cams?
Old May 2, 2003 | 11:21 AM
Gong Show's Avatar
Default Re: si pistons in b18c5 (OBDI JEDI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBDI JEDI &raquo;</TD></TR><TR><TD CLASS="quote">whats the link to the CR calculator again?</TD></TR></TABLE>
http://www.c-speedracing.com/h...c.php
Old May 2, 2003 | 12:20 PM
OBDI JEDI's Avatar
Default Re: si pistons in b18c5 (Gong Show)
thank you sir
Old May 2, 2003 | 12:30 PM
Gong Show's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBDI JEDI &raquo;</TD></TR><TR><TD CLASS="quote">thank you sir</TD></TR></TABLE>
Old May 2, 2003 | 10:24 PM
Mr.Integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">
wtf.....</TD></TR></TABLE>
i think he got his info from this thread..
https://honda-tech.com/zero...age=1
Old May 2, 2003 | 11:30 PM
sgT's Avatar
sgT
Default Re: si pistons in b18c5 (Mr.Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Integra &raquo;</TD></TR><TR><TD CLASS="quote">
Well let me clue you guys in, Michael Delaney(Tuan) doesnt know much about
engines and anything he says should be taken with a grain of salt. He's probably
good if you want specs or numbers, but for real world expertise, he has NONE.
Old May 2, 2003 | 11:40 PM
Mr.Integra's Avatar
ouch
Old May 3, 2003 | 02:38 PM
514_type R's Avatar
so anyone experienced the si pistons.....is there a really good improvement in acceleration of the car?
