Part no. for JDM rear upper arms
Old Apr 27, 2003 | 11:46 PM
sk-itr's Avatar
Default Part no. for JDM rear upper arms
Does anyone have a part number for the JDM 98 spec rear upper arms ? I've seen them on IPS etc but as I'm in the UK I'd like to see if my local honda dealer can get them.
Old Oct 22, 2003 | 06:20 AM
sk-itr's Avatar
Default Re: Part no. for JDM rear upper arms (sk-itr)
I dont think I'm going to get very far with my quest for a JDM 98 spec chassis/VIN number so does anyone have the part numbers for the uprated tubular rear upper suspension arms fitted to the 98 spec. JDM R's? I can order them from suppliers in the US (I'm in the UK) but my dealer can get it for me if he has the part number.
Old Oct 22, 2003 | 08:25 AM
Todd00's Avatar
I said I don't want a title!
The JDM pieces are tubular, but otherwise why do you really want them? They give you more negative rear camber, which usually isn't what a person wants as it promotes understeer.
You could always get a true camber kit for the rear so you can have some adjustibility.
But, IPS, R&D, AJ Racing, JDMspecperf, etc all have carried them at one time.
Old Oct 22, 2003 | 10:20 AM
sk-itr's Avatar
Default Re: Part no. for JDM rear upper arms (Todd00)
I know this has been covered before but in the BM 1 video "Mr Spoon say's" they are a good upgrade for a "96 Spec." car. They should cost around $22 a side which is less than most of the kit's I've seen.
Plus (hopfully) I can get them from 5 miles down the road not 5,000 miles across the atlantic
Old Oct 22, 2003 | 10:31 AM
Mario's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">The JDM pieces are tubular...They give you more negative rear camber...</TD></TR></TABLE>
Is that right? I have both (USDM & JDM 98spec), and have measured the specs side by side. They share the exact dimension in length, which is what determines camber correct?
Old Oct 22, 2003 | 10:43 AM
sk-itr's Avatar
Default Re: Part no. for JDM rear upper arms (Mario)
Sounds to me like the camber is the same.
The reason I'm getting them is that it keeps the camber consistent by avoiding any twist in the 96 spec part.
Old Oct 22, 2003 | 12:09 PM
jdmspoonitr's Avatar
22 a side? Maybe in Japan. In the US I have seen used sets selling for 100 dollars.
Old Oct 22, 2003 | 01:13 PM
type r 01-1063's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">The JDM pieces are tubular, but otherwise why do you really want them? They give you more negative rear camber, which usually isn't what a person wants as it promotes understeer.
I thought it would promote less understeer...
Old Oct 22, 2003 | 03:35 PM
Todd00's Avatar
Default Re: Part no. for JDM rear upper arms (type r 01-1063)
No, they are shorter from all of the measurements that I have seen, which will give you more rear camber.
And yes, more rear camber = more understeer. The more the rear end sticks to the ground, the more the car will push. But, it's a trade-off and suspension tuning is the key.
Old Oct 23, 2003 | 07:03 AM
sk-itr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario &raquo;</TD></TR><TR><TD CLASS="quote">
Do you have a part number ? My dealer is comming back the the 96 spec. part
Old Oct 23, 2003 | 09:13 PM
t's Avatar
t
Placed side to side they look to be exactly the same length.
Im interested in these measurements you have seen??
Old Oct 24, 2003 | 01:13 AM
b18c1_powered_si's Avatar
Default Re: Part no. for JDM rear upper arms (t)
anyone want to see a pair and pic of these upper rear jdm arms. i have it.
Old Oct 24, 2003 | 03:54 AM
sk-itr's Avatar
Default Re: Part no. for JDM rear upper arms (b18c1_powered_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1_powered_si &raquo;</TD></TR><TR><TD CLASS="quote">anyone want to see a pair and pic of these upper rear jdm arms. i have it. </TD></TR></TABLE>
Yes please. It'll help when I'm trying to describe them to my dealer
Old Oct 24, 2003 | 09:08 AM
i have a pair for sale.
Old Oct 27, 2003 | 02:16 PM
sk-itr's Avatar
I think I've finnaly found the part number for these with some help from DutchITR1689
The part is 52390-ST7-Z11 and you need two of them (that is there is only one part number).
I also found this showing the difference between the two.
http://babelfish.altavista.com...tlb=1
I'll phone my honda dealer tomorrow and find out how much they are in europe.
Old Oct 27, 2003 | 02:45 PM
DutchITR1689's Avatar
"There is the feeling which has become feeling hard, but as for difference it is not understood excessively. Whether difference understands when and the like penetrating of the last corner of Tsukuba, the ‚µ‚ê‚Ü‚¹‚ñ. Next Tsukuba is the pleasure. "
LOL. I think I want it too.....
Old May 21, 2004 | 01:38 PM
sk-itr's Avatar
Default Re: Part no. for JDM rear upper arms (DutchITR1689)
I got a pair of these from AJ racing when I poped over the Redmond WA in March. The arms are the same length exactly as the standard items the difference is the stiffness of the part. After having to cut one of the bolt's of that siezed I fitted both. The difference seems to be a more controlled ride over holes in road etc. The rear does'nt seem to crash about as much. The back end just feels more stable. The arms I removed were not worn much (&lt;30K miles) so I'm not sure how much of this could be atributed to the bushings on the newer part, not much I'd say....
Old May 21, 2004 | 05:14 PM
Austin's Avatar
For not a whole lot more you can go with this:
https://honda-tech.com/zerothread?id=864273
Old May 21, 2004 | 05:26 PM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk-itr &raquo;</TD></TR><TR><TD CLASS="quote">The arms are the same length exactly as the standard items the difference is the stiffness of the part. </TD></TR></TABLE>
You are the only one that I've ever heard say that. Everyone else says that they are shorter.
Old May 22, 2004 | 03:20 AM
an2ny888's Avatar
they are the same length, i lined them up side by side to compare. guess that makes me number two
Old May 22, 2004 | 06:41 AM
sk-itr's Avatar
Default Re: Part no. for JDM rear upper arms (an2ny888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">they are the same length, i lined them up side by side to compare. guess that makes me number two</TD></TR></TABLE>
I did the same
Old May 22, 2004 | 12:51 PM
db8sirg's Avatar
how much?
yeedub
Apr 18, 2013 02:09 PM
sk8shorty012
Feb 12, 2011 09:03 AM
00 FBP ItR
Jan 27, 2004 12:45 PM
N1Spec
Nov 16, 2001 10:04 AM
albert butterbikini
Sep 21, 2001 02:18 PM
