ctr pistons w/ crower cams??
Old Apr 27, 2003 | 10:03 PM
HmgLauj69's Avatar
Default ctr pistons w/ crower cams??
as the topic says, how's the setup? does it run good together? what kind of pistons would you guys prefer for crower cams?
Old Apr 28, 2003 | 03:55 AM
Charlie Moua's Avatar
Default Re: ctr pistons w/ crower cams?? (HmgLauj69)
DUE! if you want answer you have to be more specific bro?
CTR pistions in what motor?
crower cams vtec or non-vtec?
Old Apr 28, 2003 | 10:15 AM
hmongdude's Avatar
it's civic type R piston with vtec crower cams... I told a friend to post this.....So what pistons do you guys recommend for vtec crower cams?
Old Apr 28, 2003 | 11:02 AM
Default Re: (hmongdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongdude &raquo;</TD></TR><TR><TD CLASS="quote">it's civic type R piston with vtec crower cams... I told a friend to post this.....So what pistons do you guys recommend for vtec crower cams?</TD></TR></TABLE>
ok lets be smart here buddy. If you want good answers you'll have to ask better detailed questions. Don't be so lazy it's just typing..LOL
damn i wanna help a fellow hmong out but your asking a question that can't be answer.
which motor
which cams
what CR?
Old Apr 28, 2003 | 11:43 AM
hmongdude's Avatar
Default Re: (Charlie Moua)
it's for a b16a2 motor.......... with crower cams......... i need to know what kind of piston runs good with the cams.............
Old Apr 28, 2003 | 02:24 PM
HybridFiend's Avatar
CTR pistons are the best bang for the buck.... but the most you would want for a camshaft is ITR/CTR, Toda A, Spoon, Skunk2 1's, Jun 1's, or anything in that comparison. You need to be able to have some play with cam timing, and not worry about piston to valve clearance.... you need to also consider the higher your rpm the less clearance you get. .040"-.030" piston to valve clearance is a minimum with non forged internals... I have heard of .030" not clearing at 10k rpm... so be carefull... if you want to make sure "clay" your valve reliefs on the pistons?
Old Apr 28, 2003 | 02:59 PM
jdmjopey's Avatar
I have a B18C5 with CTR pistons, CTR intake cam & ITR exhaust cam....this setup works really well.
Old Apr 28, 2003 | 03:05 PM
sslude's Avatar
Default Re: (havsom)
the CTR and ITR cams are identical. but the CTR cams had a tiny bit more aggressive intake side. the 00-01 (i think) ITR's are identical to the CTR cams. i owuld get the valve springs and retainers with them, that way you could have a higher rev limit. get CTR pistons wtih CTR cams
Old Apr 28, 2003 | 03:24 PM
hmongdude's Avatar
Default Re: (HybridFiend)
how high of a compression should i get for the CTR..? are 10.8-1 good? is that the minimum?.....I really need some help here...thanks a lot guys................
Old Apr 28, 2003 | 10:18 PM
sPaRk'iT's Avatar
ttt help this guy!
Old Apr 28, 2003 | 10:47 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongdude &raquo;</TD></TR><TR><TD CLASS="quote">how high of a compression should i get for the CTR..? are 10.8-1 good? is that the minimum?.....I really need some help here...thanks a lot guys................</TD></TR></TABLE>
You do want decent compression to use with the CTR cams, but you'll notice a difference in performance even with stock compression. 11:1 is nice w/CTR cams, but it also has a lot to do with your other mods, your intentions (road race, drag, street, etc), and your tuner.
Old Apr 28, 2003 | 11:16 PM
hmongdude's Avatar
Default Re: (rodrez)
I have the stage two crower cams, titanium retainers, valve springs, and crower titanium valves already..... will ctr piston run good with it..... ??? Thanks......
Old Apr 29, 2003 | 03:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongdude &raquo;</TD></TR><TR><TD CLASS="quote">I have the stage two crower cams, titanium retainers, valve springs, and crower titanium valves already..... will ctr piston run good with it..... ??? Thanks......</TD></TR></TABLE>
yes it will run better..(than stock) man... you seem sorta lost on the info bro.
any cam upgrade will yeild better hp results! but when you install the high lift and duriation cams (jun3,toda,skunk2 stage2, ect) the higher compression the more power you can extract from the cams.
Just remember all those cams i listed love high compression motors that's how they were designed! BTW 10:1cr is not high anything 12:5 and up is called high compression
Old Apr 29, 2003 | 04:12 PM
hmongdude's Avatar
ttt
JR_Integra
Aug 27, 2011 11:23 AM
dohc_profile
Nov 13, 2007 08:32 AM
Ra GS-R
Aug 10, 2007 03:09 PM
dookieK9
Feb 11, 2005 09:09 PM
