Am I the only one on this board with a B17A1 in an EF?
Old Apr 27, 2003 | 03:35 PM
Hondasaurs's Avatar
Default Am I the only one on this board with a B17A1 in an EF?
I'm looking for anyone who has this swap or knows of anyone who has done this. I have a few questions and would like to compare wiring and vacumm setups.
Old Apr 27, 2003 | 04:51 PM
yourfacesucks's Avatar
Default Re: Am I the only one on this board with a B17A1 in an EF? (ZC_CRX)
no i got the same swap in a 91 dx i love it.........
Old Apr 27, 2003 | 06:30 PM
TheBestCRX's Avatar
Default Re: Am I the only one on this board with a B17A1 in an EF? (yourfacesucks)
sorry, i don't have the swap, but i will sometime this summer. i have the engine and everything, just need mounts and then i can put it in.
how do u like it? did u use stock b17 ecu and run it all OBD1 or did u keep it OBD0?
Old Apr 27, 2003 | 06:51 PM
fourthgenhatchB17's Avatar
what do u need to know ZC CRX? I am currently in the process of doing this swap. My wiring is done and i am running OBD-1 with the GSR P61 ECU.
Old Apr 27, 2003 | 07:36 PM
B17ACRX's Avatar
I've got one in my '91 Si. Converted to OBD0 using B16A dizzy, Zdyne 1-wire VTEC conversion ECU, and D16A6 injectors. Great engine, perfect compromise between B16 horsepower and B18 torque.
Old Apr 27, 2003 | 07:45 PM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
Default Re: Am I the only one on this board with a B17A1 in an EF? (B17ACRX)
how much did you guys pay for your swaps, using the B17 has never really occured to me, and just to clear a few things up, the bore is the same as the b16 and b18 right? If so have any of you considered tossing in a B18 crank? The B17 crank is pretty rare and a lot of guys like it for the B20 so you could make some money and get some CCs
Old Apr 27, 2003 | 08:08 PM
FFormula1's Avatar
Default Re: Am I the only one on this board with a B17A1 in an EF? (hondavtecfanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondavtecfanatic &raquo;</TD></TR><TR><TD CLASS="quote">the bore is the same as the b16 and b18 right?</TD></TR></TABLE>
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondavtecfanatic &raquo;</TD></TR><TR><TD CLASS="quote">If so have any of you considered tossing in a B18 crank? </TD></TR></TABLE>
It would result in a not so good for longevity R/S ratio plus you would need some custom short rods to use it.
Old Apr 27, 2003 | 08:51 PM
Default Re: Am I the only one on this board with a B17A1 in an EF? (Muffin')
i converted my entire car obd1........i like the swap......its a really nice swap it has given me no problems.........no check engines and i deliver pizzas all day.....
Old Apr 27, 2003 | 10:20 PM
Cvic90's Avatar
I've got It in my 90 Si hatch. I love it. Made my own OBD-1 conversion. The only thing I didn't do that I'm thinking about is the Fuel pressure solonoid control. I haven't had any problems from it though. The tranny is soooooo much better than any jdm cable.
Old Apr 28, 2003 | 05:11 AM
Hondasaurs's Avatar
Default Re: Am I the only one on this board with a B17A1 in an EF? (fourthgenhatchB17)
I have the swap done. I've been driving the car for 2 weeks now. I have a few ECU codes like O2 heater, IAC, and Vtec oil pressure, which I bypassed. 1st I had to convert the car to MPFI. Then I had to convert it to OBD1. I did this by splicing the ECU into the OBD0 wires by cutting the OBD0 ECU plugs off. I've found a few mistakes in my wiring conversion, but nothing I could not fix in a matter of minutes. I'd just like to see some pics of this swap from anyone who has it.
Old Apr 28, 2003 | 06:37 AM
Shawn C's Avatar
In The Garage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B17ACRX &raquo;</TD></TR><TR><TD CLASS="quote">I've got one in my '91 Si. Converted to OBD0 using B16A dizzy, Zdyne 1-wire VTEC conversion ECU, and D16A6 injectors. Great engine, perfect compromise between B16 horsepower and B18 torque.</TD></TR></TABLE>
you should really consider running some B16A, B18A, etc injectors or something. that engine needs some 230cc injectors to run right. also, you need (if you don't already have it) a b-series fuel pump. my friend ran a gs-r swap on d-series injectors and fuel pump, and it detonated some. then we installed b-series stuff, and it ran like a scalded dog (i'm speaking of Plan B's setup). just my .02
-Shawn
Old Apr 28, 2003 | 09:49 AM
russian_racer's Avatar
I just got a B17 put into my 88 crx. Runnin ODBO w/ b16a ECU (I was told it gets better power than the B17 ECU??), B16 injectors (which are better), and I beleive a LS dizzy,high flow fuel pump...runs smooth and hella fast....its got e/h/cat./cai/apexi vtec controller
Old Apr 28, 2003 | 11:00 AM
E-lude78's Avatar
I have a B17A in my '88 hatch. I'm running OBD1 with the stock P61 ECU. Never had any problems since I first started it up. I might install CTR pistons in the future
Old Apr 28, 2003 | 02:11 PM
RuffRhyno's Avatar
Default Re: Am I the only one on this board with a B17A1 in an EF? (Mista B-one-seven)
92 B17a1 in my 91 CRX DX. Using JDM S1 trans on OBD0 B16a distributor, fuel injectors, and I just upgraded my ecu to a Zdyne Gold (building turbo kit on the side). I am currently having some issues with the motor that I think could be related to fuel injection, but I am not getting any codes. I have re-done my MPFI wiring over and over and nothing is wrong with it. Oh well, I haven't really gotten to experience this thing yet...
Old Apr 28, 2003 | 03:00 PM
Hondasaurs's Avatar
Default Re: Am I the only one on this board with a B17A1 in an EF? (RuffRhyno)
Most of my CEL codes were from mistakes I've made in the wiring. So far I've elimanated 7 codes down to 2. I have a CEL for O2 heater (41) and and code 10, possible wire related.
Old Apr 30, 2003 | 03:35 PM
B17ACRX's Avatar
Default Re: Am I the only one on this board with a B17A1 in an EF? (22lbGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R &raquo;</TD></TR><TR><TD CLASS="quote">
-Shawn</TD></TR></TABLE>
According to the specifications I've seen, the D16A6 already has 240cc injectors... anyone have more info on this?
Old Apr 30, 2003 | 04:16 PM
RuffRhyno's Avatar
all civic/integra oem injectors flow at 240cc's. No difference between "first gen B16a injectors" or "crx injectors". Anyone who tells you otherwise, is full of it.
Old Apr 30, 2003 | 05:16 PM
i actually have my car ran obd1 with prelude injectors and i like it my swap was a pain in the *** first we had to make the wiring for mpfi then we had to make the car a standard from an auto it was a fun time.....i like the swap and for some reason its really fast like i take out j spec gsr efs all day *cough chris cough* no i havent beat him yet but i stress on yet your day will come chris but anyways yes its a fun swap and i suggest running the car obd1 and using prelude injectors it was faster this way........
GonzoWerke
Engine Management and Tuning
Mar 21, 2018 10:49 AM
88 EF Hatch
Aug 8, 2009 12:24 PM
wood
32
Mar 3, 2006 02:36 AM
usdm_ED7
Nov 4, 2002 02:55 PM
