What Clutch/Flywheel for DOHC ZC?
Old Apr 27, 2003 | 03:34 PM
Ronin Panda's Avatar
Default What Clutch/Flywheel for DOHC ZC?
^^^ What are my options when it come to this?^^^
Old Apr 27, 2003 | 03:36 PM
Hondasaurs's Avatar
Default Re: What Clutch/Flywheel for DOHC ZC? (Touge Panda)
When I had my ZC I used a Centerforce Dual Friction clutch. It was well worth the money.
Old Apr 27, 2003 | 03:40 PM
Default Re: What Clutch/Flywheel for DOHC ZC? (ZC_CRX)
Thanks man...but when i shop for a clutch ..what car do i buy one for?
do i order a clutch or a flywheel for a 88-89 integra? .
you know what im sayin?
Old Apr 27, 2003 | 03:43 PM
Hondasaurs's Avatar
I used an 89 CRX Si tranny and flywheel on my ZC. So thats the clutch I purchased (89 CRX Si ). So, I would say get the clutch that goes with your tranny and flywheel.
Are you using the ZC tranny?
Old Apr 27, 2003 | 03:47 PM
im using a std 4spd temporarly until i find a 4g SI trans...
but if i bought a clutch for a 89 civic si...will it work on the 4spd and then later on i can just swap trannys to the si trans?
Old Apr 27, 2003 | 03:51 PM
drjondurst's Avatar
If you're using a 4 spd STD tranny, get a 4spd STD clutch and flywheel. The flywheel and clutch always have to match the tranny.
Old Apr 27, 2003 | 03:54 PM
Default Re: What Clutch/Flywheel for DOHC ZC? (drjondurst)
So im not even gonna **** with it now then ..i dont plan on having that trans for much longer ill just wait and get the clutch/fly for whatever trans i get.
thanks
EDIT: let me clear something up ..im still a little confused...if i have a 89 civic si trans...i order a clutch/fly for a 89 civic si ..even though that i dont have the A6 motor in my car and the clutch/fly bolt to the motor?
make sense?
thanks guys
Modified by Touge Panda at 1:10 AM 4/28/2003
Old Apr 27, 2003 | 04:28 PM
anyone?
Old Apr 27, 2003 | 04:31 PM
FourthGenHatch's Avatar
Yes get the clutch and flywheel for whatever trans it is you are using.
Old Apr 27, 2003 | 04:44 PM
Hondasaurs's Avatar
Any D series flywheel will bolt to a ZC.
Old May 11, 2003 | 09:38 AM
mbsi's Avatar
Default Re: What Clutch/Flywheel for DOHC ZC? (B17A Hatch)
is it possible to use the clutch from an 89 and the pressure plate from a 90 on a 90 zc tranny. Is there a difference in size for the clutch disk itself or is it just the pressure plate that varries in size? I heard the clutch disk is different in size for the 88, 89 and 90-91 but 90-91 are the same so 3 different sizes. Also is the zc's architecture the same as an L3 d series, meaning the input shaft, and flywheel size are they all the same as the d series threwout 88-91.
Old May 11, 2003 | 11:56 AM
durrett syndrome's Avatar
Default Re: What Clutch/Flywheel for DOHC ZC? (mbsi)
i got a clutch specialtieS 6 puck sprung hub clutch. VERY nice iwth stokc zc flywheel
Old May 11, 2003 | 12:02 PM
mbsi's Avatar
Default Re: What Clutch/Flywheel for DOHC ZC? (durrett syndrome)
so the flywheel sizes on the zc are the same as the d series ones?
Old May 11, 2003 | 02:42 PM
MONSTERZC's Avatar
like the post above you can use any d ser flywheel. it the slpine's on the input shaft that are different 88-89 use the same disc and the 90-91 use the same disc
Old May 11, 2003 | 02:52 PM
redzcstandardhatch's Avatar
something different
Default Re: What Clutch/Flywheel for DOHC ZC? (MONSTERZC)
i think only the 88 splines are different, i have a 89 tranny(supposedly its an 89, it was taken out of an 89 rex) working fine with a clutch that was used for a bit on a 90. they flywheel is an 89
Old May 11, 2003 | 05:05 PM
mbsi's Avatar
if u can read english I asked if the zc flywheels are the exact same size as the d series flywheels, NOT if the zc motor is capable of using a d series flywheel.....
plus the 88 clutch disk is 190mm, the 89 is 200 mm so 88 and 89 are not the same
I Have an STD
May 4, 2005 05:58 PM
Creepshow S60
Nov 11, 2004 10:32 AM
phatrick2332
Mar 31, 2004 06:11 AM
giantdumbass
10
Oct 18, 2003 11:53 AM
crxnug
Dec 8, 2001 12:31 PM
