spoon thermostat and thermoswitch....
i have both on my car with the stock radiator
my temp needle does not go past the 1/4 mark...
during winter driving it dips below that...but my R is not a daily driver so it doesn't concern me too much...
The thermostat is too cold for daily driving IMO. The fan switch is fine. I recommend the Mugen thermostat with the spoon/mugen thermoswitch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">The thermostat is too cold for daily driving IMO. The fan switch is fine. I recommend the Mugen thermostat with the spoon/mugen thermoswitch.</TD></TR></TABLE> the reason i was asking is that im turbocharged and according to my hondata datalogger my engine temp is runnin at 200 degrees(thats on a cool night), my fan runs almost constantly so before summer really gets here and the temptures really get hot i wanna get my tempture down some.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekkedR »</TD></TR><TR><TD CLASS="quote"> the reason i was asking is that im turbocharged and according to my hondata datalogger my engine temp is runnin at 200 degrees(thats on a cool night), my fan runs almost constantly so before summer really gets here and the temptures really get hot i wanna get my tempture down some.</TD></TR></TABLE>
I am runnin the spoon thermo... and even on the track it didnt get up to normal temperatures... not running turbl0w but higher compression... bitch never gets hot.
The answer is a simple one; you want the engine to be running at the normal operating temperature. No lower, no higher.
Monitor your engine temps and if they are too high then upgrade the cooling system. If not, don't worry about it.
You want the engine to run at the temperature it was designed for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 »</TD></TR><TR><TD CLASS="quote">The answer is a simple one; you want the engine to be running at the normal operating temperature. No lower, no higher.
You want the engine to run at the temperature it was designed for.</TD></TR></TABLE>
sounds good..
sounds good..
saikouEF8
Sep 5, 2006 07:23 AM
