OBD-1 Injectors on a OBD-0 System
i believe all you'd have to do is eliminate the resistor box. you cant just unplug it though; youd have to connect all five of the wires together, essentially jumping out where the resistors used to be to complete the circuit. this way it will be the correct impedance.
i ran obd-1 injectors from a z6 on my a6 ... i didnt have a problem with it at all and i was still runninmy resistor box... as for the plugs if you look at the obd-0 plus and the obd-1 injector you will see that you only have to dremel out the little out dent lookin think on them and it will work... take a look at it and im sure you can do somethin with it...
from what i know the obd-0 injectors are peek and holds and the obd-1 are just peaks
scarponze
scarponze
surkitroller
Dec 29, 2009 12:58 PM
e jay one
Sep 10, 2005 09:15 AM
my mistake
