Much love for the 1st gen CRX (engine swap is done!)
That's an 89 Integra D16A1 engine. See my website in my sig for all of the details.
I need a PR3 ECU if someone's got one. Lemme know.
Thanks,
Sonny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX PAT »</TD></TR><TR><TD CLASS="quote">Looks good, but is that an automatic tranny I see?</TD></TR></TABLE>
I don't think that is an auto look at the fire wall near the stearing column and I see what I think is a clutch cable
Pat:
Did you use the Hasport kit to put the B16A into your car? Man, I would like to have done that, but the kit and axles were sooo expensive.
I coulda waited and saved, but JDM engine swaps are not legal in Cali. So, turbo D16A1 is what I'm going to do. Converting over to the 89 electronics was a loooot of work. I ended up moving about 25 wires and I had to make the ELD and VSS work. It was worth it though. It's running good.
Sonny
Teg tranny has good gearing. I believe it's a closer ratio gearbox than the L3 tranny that comes on the black top ZC and D16A6.
I want a PR3 because I have a Hondata Stage 4 system that I used on my old Civic. The PR3 is a logical choice for me right now. I already know how to deal with the VTEC solenoid and knock sensor inputs. Eventually, I'll convert to OBD1 but I'm kinda sick of dealing with wiring right now.
I hope the have the turbo on the car at around 2000 miles. We'll see. I'm fabbing up 2.5" exhaust first and I also have a pair of ef-1's ZC turbo cams.
Sonny
Why didn't you use the 86-87 teg engine and ecu? When I had my 1st gen I was planning on converting over the brakes,engine, and ECU from a 86-87 teg. I was under the impression that everything just bolted in.
The 86-87 Teg engine/ECU is basically a direct bolt in with no wiring changes. However, that setup also uses a vacuum-advance distributor that is not compatible with any form of engine management since you have no control over the ignition timing.
Sonny
Sonny
ekoms31
Mar 9, 2005 06:36 AM
