Hydraulic clutch line help for H22 EG swap!! ASAP!!!!!!
Old Apr 26, 2003 | 07:34 PM
UpstateCivic's Avatar
Default Hydraulic clutch line help for H22 EG swap!! ASAP!!!!!!
The hydro clutch line on the h22 is similar to a fuel line. What do I need to do to convert this to work w/the civic lines??
Old Apr 26, 2003 | 10:59 PM
Slurp56's Avatar
Default Re: Hydraulic clutch line help for H22 EG swap!! ASAP!!!!!! (UpstateCivic)
go to your local parts store and find some brake line. Then remove that little fitting and run the line from your civic (using a coupler) to the slave cylinder directly.
Old Apr 27, 2003 | 06:47 AM
Jonathan_ED3's Avatar
Default Re: Hydraulic clutch line help for H22 EG swap!! ASAP!!!!!! (Slurp56)
If you've got the kind of clutch line (on the h22), where it's got a valve, and then a banjo fitting at the end of the stock rubber line.....take off that whole valve. Then run your stock Civic rubber to where the valve used to go. Works like a charm.
Old Apr 27, 2003 | 12:15 PM
MPower332TI's Avatar
Default Re: Hydraulic clutch line help for H22 EG swap!! ASAP!!!!!! (hot_EG)
Basically you do this. Take the clutch line loose from the slave cylinder on the stock civic tranny. Stick it to the side of the engine bay. Now when the H22 is mounted in the civic take the line and attach it to the H22 trany slave cylinder. You might have to bend it a little to make it look nice put it has plenty of length on it and fits nice. Dont worry about any of the soft line **** on the H22 trans. Take it all off all the way to the slave cylinder. Hope that helps.
antivic
Aug 8, 2005 08:20 AM
EGhatch22
Dec 14, 2004 05:19 PM
mdj_ge
Nov 16, 2004 07:48 PM
jdmcivicferio
Feb 19, 2003 04:30 PM
