jim fab bar on crx??
if my freind puts one of these jim fab bars on his crx,will it allow him to use the LS a/c bracket on his LS.
he would rather spend the $250 on the bar rather than the $250 on a new a/c bracket.
is 90 crx si with a LS swap in it.
You talking about the Compressor? or the Condensor or what? Compressor has nothing really to do with the Crossmember, maybe you mean Condensor but I don't think that really is supported by the crossmember at all.
The condensor just sits on the frame and is bolted on the sides, just took mine out so its fresh in my mind. Are you wondering if the compressor will fit between the radiator and block? With Jimfab I am not too sure if the radiator is pushed forward or not. I don't think it is. Just go the non-AC route and save ~50lbs.
Yes. the Teg compressor will fit. I put on my jim-fab and what do you know, I don't have to buy the HAsport A/C bracket. I haven't put it on yet, but it will fit. I checked mine last week. Putting my A/C back on next.
Buy a turbo and 50lbs of A/C is nothing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cvic90 »</TD></TR><TR><TD CLASS="quote">Yes. the Teg compressor will fit. I put on my jim-fab and what do you know, I don't have to buy the HAsport A/C bracket. I haven't put it on yet, but it will fit. I checked mine last week. Putting my A/C back on next.
Buy a turbo and 50lbs of A/C is nothing.</TD></TR></TABLE>
thank you,that what i was wanting to know.
the a/c will not bolt up on the l/s in a crx unless you buy the hasport bracket for $250,because it hits the stock crossmember.so instead of spending that cash on a a/c bracket ,we will spend it on a jim fab bar.make sense?
rx191
Sep 19, 2012 09:35 AM
