GSR Block, Eagle Rods, Tech Edge Wb w/ sensor, and more stuff..
Old Apr 26, 2003 | 04:12 PM
SlowTeg's Avatar
Default GSR Block, Eagle Rods, Tech Edge Wb w/ sensor, and more stuff..
I'm located in Northern Va, local buyers preferred. Shipping is extra.
1. 94-95 GSR block COMPLETE, has a cracked sleeve, perfect for resleeving. The Al water jacket got pushed out about 2 inches down from the top, will work fine for sleeves that replace a good portion of the water jacket such as GE or Darton. The block comes w/ EVERYTHING, crank, caps, girdle, pan, oil pickup, knock sensor, water neck, factory oil cooler, etc. I cracked a sleeve a while back and was thinking of rebuilding this in the future but am thinking of just selling it. Crank is in perfect shape, was previously balanced and journals polished. $450 OBO
2. GSR eagle rods- Rods are in perfect condition, they have about 15k miles on them but look nearly brand new. $200 firm
3. Tech Edge WB v1.0 w/ cable and ntk sensor- The sensor probably has around 5k miles on it, the unit is in perfect shape and it's all in good working order. I have the display as well, but I must have been careless with it and it stopped working. If you're familiar w/ electronics you might be able to fix it for cheap, I'll give you that as well. Make Offer.
4. GSR Intermediate shaft- $75 OBO
5. Neuspeed front upper black strut bar for 96+ civic- Neuspeed sticker is coming off otherwise good shape $50 OBO
6. 95 GSR complete intake manifold/fuel rail/injectors/TB/sensors etc.- Busted TPS sensor that's it.. Make an offer.
7. Stock GSR flywheel- Good shape, make an offer..
8. GSR 3rd/4th gear syncro(they're the same)- Shifted fine while it was in the tranny, just hate to throw it away. $20..
Please no lowballers, just reasonable offers. Email or h-t pm is the easiest way to reach me. Thanks.
-Mike
EDIT: I'm looking for a set of gsr wheels so I'll consider trades if you're local.
Modified by SlowTeg at 3:48 AM 5/17/2003
Old Apr 26, 2003 | 09:55 PM
SlowTeg's Avatar
Default Re: GSR Block, Eagle Rods, Tech Edge Wb w/ sensor, and more stuff.. (SlowTeg)
Responded to all pms.. up..
Old Apr 27, 2003 | 11:43 AM
SlowTeg's Avatar
up again..
Old Apr 28, 2003 | 02:40 PM
SlowTeg's Avatar
bump.. I just added a note to anyone that's interested thanks.
Old May 11, 2003 | 10:09 PM
Speedworks801's Avatar
Will you take $300 for your GSR Block?
Thanks
Old May 12, 2003 | 11:28 AM
Datum1Tuning
Guest
Posts: n/a
What model is the eagle rods?? h-beam??
Old May 13, 2003 | 05:13 PM
SlowTeg's Avatar
Default Re: (Datum1Tuning)
To my knowledge eagle only makes one kind of rod for the B18c.. I think it's h-beam.. but they only make one last time I checked.
-Mike
Old May 16, 2003 | 11:48 PM
SlowTeg's Avatar
up again...
Old May 17, 2003 | 12:02 PM
RedHB's Avatar
still have the synchros?
Old May 17, 2003 | 06:54 PM
SlowTeg's Avatar
Default Re: GSR Block, Eagle Rods, Tech Edge Wb w/ sensor, and more stuff.. (RedHB)
sorry i think it's sold, just haven't got the definite ok from the buyer. I'll let you know if it's not sold. Thanks.
-Mike
97dcteggy
Sep 5, 2014 07:32 PM
chocolatecivic
Southeast (Sales)
Apr 16, 2010 09:56 PM
253kingpen
Northwest (Sales)
24
Mar 30, 2009 12:22 AM
DurrtyracingMIA
Nov 26, 2008 09:03 PM
