window washer and window gasket 92 ex HELP!!!
Old Apr 26, 2003 | 03:41 PM
Phire's Avatar
Default window washer and window gasket 92 ex HELP!!!
Ok so here's the deal......My winshield washers weren't working so I replaced the pump, checked the fuse and the sprayers. It still doesnt work, there is no fluid in the lines, what gives??? I know I wired the pump right...........
Also, my passenger side window gasket was installed wrong by the previous owner and I attempted to take up the slack back down into the door.........but failed
Is there any way to fix this without taking off the door panel?
Thanks for any help
Old Apr 27, 2003 | 08:12 AM
Phire's Avatar
anyone?
Old Apr 27, 2003 | 08:22 AM
urbanlegend21's Avatar
New User
Default Re: (Phire)
the only thing I can say about the gasket without removing it is to cut a small section out of it
as far as your windshield washer goes I know it sounds simple but have you checked your fuses and or grounding?
Old Apr 27, 2003 | 08:23 AM
BB6-00's Avatar
Default Re: window washer and window gasket 92 ex HELP!!! (Phire)
Is their any power going to the washer punp? and how much power is going thier?
That can affect it too.
Old Apr 27, 2003 | 11:52 PM
briq4's Avatar
Default Re: window washer and window gasket 92 ex HELP!!! (BB6-00)
remove the door panel, you can then pull the gasket down easily once you remove the panel. The gasket goes all the way down the window track.
Old Apr 28, 2003 | 01:44 PM
Phire's Avatar
ah thanks briq.......almost got the door panel off now
tercelrcr
Paint and Body
Dec 1, 2013 08:12 AM
kustomgixxer13
Feb 24, 2013 04:54 AM
irk617
May 7, 2008 04:27 PM
oaking
Jan 17, 2007 03:32 PM
GapxGuy
May 25, 2006 05:32 PM
