window gasket
Old May 7, 2008 | 01:40 PM
irk617's Avatar
Default window gasket
for some reason my window gaskets are bunching up on my dr. side window 90 acccord ex what can i do to fix this gasket problem from stopping it from stopping my window???help its 80 out and my a/c com. **** the bed
Old May 7, 2008 | 04:27 PM
hondadude's Avatar
Default Re: window gasket (irk617)
The window run channel can be worked back into place if you remove the door panel. After you work the run channel back down into place; Then glue the bottom 3" of the run channel into the metal bracket with 3M trim adhesive.
Then while the door panel is off, lube the run channel with silicone spray or Shinitsu grease.
Every time you get an oil change lube the run channels, as much as you can get to on top.
tercelrcr
Paint and Body
Dec 1, 2013 08:12 AM
oaking
Jan 17, 2007 03:32 PM
GapxGuy
May 25, 2006 05:32 PM
Jorsher
May 18, 2006 12:42 PM
Phire
Apr 28, 2003 01:44 PM
