OEM Sway Bar Help. Please! What size bolt is needed for the oem sway bar:?
Old Apr 26, 2003 | 09:43 AM
24hourflipness's Avatar
Default OEM Sway Bar Help. Please! What size bolt is needed for the oem sway bar:?
highlighted the piece in red where i need bolts for. Anyone know the size? it's for the Rear OEM Sway bar. i did a rear disc conversion (took it all of an crx si) but i dont seem to have the bolts for that part. All the bolts that came w/ the swap tend to be too small. I'm puttingit on my 88 crx dx. thanks!
Old Apr 28, 2003 | 02:32 PM
bump
Old Apr 28, 2003 | 02:51 PM
Outsane's Avatar
Default Re: OEM Sway Bar Help. Please! What size bolt is needed for the oem sway bar:? (24hourflipness)
I can't see any of those pics..
Old Apr 28, 2003 | 03:07 PM
sslude's Avatar
pics arent working...
Old Apr 28, 2003 | 04:02 PM
tominos's Avatar
Default Re: OEM Sway Bar Help. Please! What size bolt is needed for the oem sway bar:? (sslude)
pics don't work.
Old Apr 29, 2003 | 12:54 AM
Old Apr 29, 2003 | 12:57 AM
sorry for the inconvenience.. the pics wont post here.. here's the link:
http://www.houston-imports.com...13777
Old May 1, 2003 | 01:54 PM
bump!
Old May 1, 2003 | 01:57 PM
JoshDM's Avatar
Default Re: (24hourflipness)
part# is 95701-10025-08 $.93
any honda dealer can order them for you
Old May 1, 2003 | 03:56 PM
Toptul_Honda's Avatar
New User
Default Re: (JoshDM)
hi if your car is a dx like mine, there are no threads for the bolts!!
so what you have to do is drill a hole all the way up and cut a portion out so you can feed a nut to the top and then use the bolt fomr the bottom.
The size is M10
Old May 1, 2003 | 10:38 PM
New User
Default Re: (G2-Rex)
i just did this today and i also used big washers up top
Old May 1, 2003 | 10:44 PM
can anyone of you two tell me how big of a hole you drilled? also pics woudl help! thanks!
Old May 1, 2003 | 11:23 PM
markw's Avatar
Go with an ST rear bar and stock front, you'll be amazed, even if you had an Si rear.
Old May 2, 2003 | 06:03 AM
Does the St sway bar have the hardware to mount to a DX?
Old May 2, 2003 | 09:53 AM
New User
well just drill from the bottom up (with a long drill bit) to check where the holes are. Then use a rotating cutter to cut 3 slits to bend the metal up. Make sure the cut is right about the bolts holes and large enough to get big washers in there
rybred
Honda S2000
Feb 14, 2007 03:18 PM
deviant1
Acura TSX
Dec 1, 2004 11:46 PM
EG8R
Feb 29, 2004 03:28 PM
CRexcellence
Dec 2, 2003 05:14 PM
24hourflipness
Apr 13, 2003 05:06 PM
