what is an oil catch can and what is its purpose?
Old Apr 26, 2003 | 09:15 AM
Raocorp's Avatar
Default what is an oil catch can and what is its purpose?
anybody know.....I have always wanted to know what it is and what it does.
Old Apr 26, 2003 | 01:59 PM
TwistedSI's Avatar
I believe it goes inline between the intake and valve cover. On turbo motors it is comon for oil to blow through this line and make it into the intake and of course through your motor. The catch can catches that oil so that your crankcase still has ventilation but no oil makes it to your intake. But I might be wrong.
Old Apr 26, 2003 | 02:05 PM
Nameless RB26's Avatar
Default Re: (TwistedSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwistedSI &raquo;</TD></TR><TR><TD CLASS="quote">I believe it goes inline between the intake and valve cover. On turbo motors it is comon for oil to blow through this line and make it into the intake and of course through your motor. The catch can catches that oil so that your crankcase still has ventilation but no oil makes it to your intake. But I might be wrong.</TD></TR></TABLE>
Catchcan goes inline between your PCV valve and the intake manifold.
This filters small amounts of oil from crank ventilation which is routed into your manifold and down into the cylinders. You're right about the last part..
Old Apr 26, 2003 | 02:19 PM
Raocorp's Avatar
Default Re: (Nameless EJ6)
so its only for boosted applications?
Old Apr 26, 2003 | 02:25 PM
Steve Berman's Avatar
Default Re: (Raocorp)
Im curious about this also. Im sure theres a logical reason, but my fist instinct is, why would you want to burn oil? Especially with FI.
EDIT: w00t! 700 Posts!! \ /
Old Apr 26, 2003 | 02:38 PM
clm's Avatar
clm
Default Re: (Steve Berman)
Nameless said it correctly. And you can use it on FI and NA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve Berman &raquo;</TD></TR><TR><TD CLASS="quote">Im curious about this also. Im sure theres a logical reason, but my fist instinct is, why would you want to burn oil? Especially with FI.
EDIT: w00t! 700 Posts!! \ /</TD></TR></TABLE>
You don't want to burn oil. The catch can is there so you won't burn oil.
Old Apr 26, 2003 | 04:31 PM
nsxmatt's Avatar
Default Re: (clm)
Also lowers the octane level if you run the crankcase fumes/oil back into the intake. Even more so I would guess if you have some blowby.
Old Apr 26, 2003 | 05:12 PM
piscorpio's Avatar
Default Re: (nsxmatt)
Ive seen people put what looks like a small K&N cone filter on the valve cover as well, is this basically the same effect, in a more "dirty" way?
Old Apr 26, 2003 | 06:38 PM
clm's Avatar
clm
Default Re: (piscorpio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piscorpio &raquo;</TD></TR><TR><TD CLASS="quote">Ive seen people put what looks like a small K&N cone filter on the valve cover as well, is this basically the same effect, in a more "dirty" way?</TD></TR></TABLE>
Yes it is, but I don't think I'd do it. I've heard of black oil "rings" being left.
Old Apr 26, 2003 | 07:42 PM
piscorpio's Avatar
Default Re: (clm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clm &raquo;</TD></TR><TR><TD CLASS="quote">
Yes it is, but I don't think I'd do it. I've heard of black oil "rings" being left.</TD></TR></TABLE>
Being left where? Just splatter in the engine bay?
Old Apr 27, 2003 | 02:22 AM
clm's Avatar
clm
Yes, it'll leave oil "rings" in the engine bay since it just vents to the atmosphere.
jrdnwheeler
Sep 3, 2008 08:48 AM
thomas188
Oct 7, 2006 05:28 PM
JDMcb7
Apr 24, 2005 10:31 PM
jdmgeorge
Feb 10, 2004 06:55 PM
Dx_Civic_Dx
Oct 13, 2003 02:04 AM
