Any tips on painting black stuff on the rex?
Old Apr 26, 2003 | 06:34 AM
Blaze45's Avatar
Brrraaaap!
Default Any tips on painting black stuff on the rex?
Most of the black trim is faded on my car and I want to repaint it. Stuff like rear view mirrors little peices of trim ect. Should i sand it w/a 200 gt. and paper and then let them shoot it? Im going to have a heavy car paint put on it, not spray paint.
Blaze
Old Apr 26, 2003 | 07:33 AM
bfrank81's Avatar
Default Re: Any tips on painting black stuff on the rex? (Blaze45)
I think at Pep Boys they have this stuff that you can paint vinyl trim with. Make sure that it is really dry before you put it back onto the car or it will chip.
Old Apr 26, 2003 | 09:05 AM
RCautoworks's Avatar
Default Re: Any tips on painting black stuff on the rex? (bfrank81)
Not sure but I know this works on the bumper, use a hair dryer. It also works on some of the trim, not all.
Old Apr 26, 2003 | 01:29 PM
FourthGenHatch's Avatar
Default Re: Any tips on painting black stuff on the rex? (90blackcrx)
I've heard of using a heat gun to burn the surface of the black stuff and makes it turn dark again.
Old Apr 26, 2003 | 03:07 PM
91JDMHATCH's Avatar
Try using a scuff pad to get just the top layer of stuff off and respray. Should work. Good Luck
Old Apr 26, 2003 | 03:16 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: Any tips on painting black stuff on the rex? (91JDMHATCH)
i used this stuff called, "bumper black" that i got from autozone. Used it on my moldings, worked good.
Old Apr 26, 2003 | 03:20 PM
CYBEREXII
Guest
Posts: n/a
i am doing the same thing, i have already done some of the trim and it works really good.
first i got this stuff from a paint store, it is a spray can of "plastic prep" then a can of "black bumper coat" both by the same brand name. then scuff up the plastic with a 3m pad. clean it with the plastic prep, let it dry, then paint lightly with a few sweeping coats. it looks as good as new.
Old Apr 26, 2003 | 07:13 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Any tips on painting black stuff on the rex? (CYBEREXII)
Hey thanks!
Blaze
Old Apr 27, 2003 | 10:39 AM
Blaze45's Avatar
Brrraaaap!
O yeah where did you pick that stuff up from?
Old Apr 27, 2003 | 01:24 PM
civbeater90's Avatar
trim black spray paint
Old Apr 27, 2003 | 05:09 PM
NAsohcNovtec's Avatar
Default Re: Any tips on painting black stuff on the rex? (civbeater90)
I would use a red scuff pad , grease & wax remove them and use a trim black , that u can get anywhere.
Old Apr 27, 2003 | 10:38 PM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
Default Re: Any tips on painting black stuff on the rex? (NAsohcNovtec)
use BACK TO BLACK, you can find it at any discount parts place, its in the body care section at autozone which is where I got mine but it works like a charm
mynameizstitch
Mar 10, 2012 10:12 AM
steveharrmr23
Nov 15, 2008 09:24 PM
therealitsjustme
May 30, 2004 07:49 PM
al3e
Apr 25, 2003 02:37 PM
rsx03
Jun 28, 2001 06:15 PM
