newer time map sensor
that means that i just have too extent the wires of the old map to the new map on the TB??
doesn't the conectors change??
it should just plug in and if you're crafty, I think you can get away without having to extend the wires.
Why change to a TB mounted map sensor though? Get a new TEG TB?
From: the asshole of america..., upstate new york, USA
ive got a 90 integra throttle body for sale....its 58mm (vs 55mm stock) and uses the origional map sensor, no screwing around with extending wires. its setup exactly the same as the d16a6 TB...vacuum lines are run the same. let me know if your interested at all.
david22ky
19
Aug 21, 2007 08:11 PM
ENJOI
11
Aug 23, 2006 10:39 AM
Yellow Dragon
Jul 23, 2003 02:01 PM
