springs and shocks
Old Jun 30, 2001 | 10:34 PM
Stage5Lude's Avatar
New User
Default springs and shocks
need some help here...dudes.
is it better to have low spring rate(soft) with hard shocks or is it better to have a high spring rate with soft shocks???
thks in advance
Old Jul 1, 2001 | 08:39 AM
rioninja's Avatar
Default Re: springs and shocks (Stage5Lude)
It all depends on where your gonna be driving the car. I'm no expert on this, but i know higher spring rates with softer shocks will make your car a hell of a lot bouncier.
Old Jul 1, 2001 | 09:57 AM
Vitt1's Avatar
Default Re: springs and shocks (RioNinja)
Your shocks always have to be stiff enough to 'dampen' the springs. So it's never better to have stiffer springs than shocks. Like RioNinja said, if the springs are stiffer than the shocks, then you are riding on bouncing springs. The shocks don't have to be all that stiff, depends on your application; and there are adjustables so you can change the set up. If you want a good explanation on shocks and springs relationship, go here: http://www.grassrootsmotorsports.com
click on tech topics, then shocks.
sqeekyclutch
Dec 10, 2004 06:16 PM
spoolinq
Jan 13, 2003 07:30 PM
jonoknut
Sep 8, 2002 07:24 PM
Type Goch
May 2, 2002 10:54 AM
Provolone
Apr 29, 2002 07:44 PM
