Honda S2000 Honda S2000
Takata Harness w/o Roll Cage Install?
Old Apr 25, 2003 | 04:59 PM
Mocky57's Avatar
Default Takata Harness w/o Roll Cage Install?
Before people explain to me the pros/cons of no rollcage and harness (I've read the posts, did the research, etc..), I'm curious to know if it is possible or not. And, if it is possible, how was it done, and do they have any pictures? I've read posts where people have posted suggestions on how it could be done and have seen pictures with the harness (but not attached). I'm curious if this is possible since I'm yet to see it. Thanks!
Old Apr 25, 2003 | 07:13 PM
hybrids2k's Avatar
Default Re: Takata Harness w/o Roll Cage Install? (Mocky57)
I actually just installed takata harness in my s2k w/o roll cage. What i did was weld a metal plate under the car and welded a 15mm nut and bought longer bolts for the harness at the hardware store so they would reach all the way through to the bottom of the car makeing a much sturdier connection rather than redrilling and screwing in an ugly metal plate inback of the seat. For the top I drilled a hold in the stock roll bar and welded that so it wouldn't go anywhere and also repainted the roll cage so it would look clean. I like how it looks and works pretty good. I gave much thought to it and figured this was the best, cleanest way to go without compromising saftey
-David
Simon Tibbett
10
Jan 9, 2010 12:03 PM
EusebioSam19
Aug 20, 2009 02:01 PM
Mag00n
Aug 3, 2006 06:28 PM
teggytegteg
May 13, 2004 02:27 AM
mr_ben
Mar 17, 2004 10:55 AM
