good oem brakes on a eg
Old Apr 25, 2003 | 03:57 PM
wm5holla's Avatar
Default good oem brakes on a eg
what some good brakes on a eg.. gsr, itr?
Old Apr 25, 2003 | 04:20 PM
beeboyee's Avatar
Default Re: good oem brakes on a eg (wm5holla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">what some good brakes on a eg.. gsr, itr?</TD></TR></TABLE>
huh? brake pads?
Old Apr 25, 2003 | 04:25 PM
wm5holla's Avatar
Default Re: good oem brakes on a eg (beeboyee)
well i think i need new pads how much bigger are gsr rotors from EGs?
Old Apr 25, 2003 | 05:56 PM
Echo7847's Avatar
theyre the same size
Old Apr 25, 2003 | 08:11 PM
turbosol's Avatar
Default Re: good oem brakes on a eg (Echo7847)
I perfer the ITRs, my friend had a gsr with brembo cryo treated cross drilled rotors, goodridge lines, and a number of differrent pads and the braking force never came close to my stock ITR brakes.
Old Apr 25, 2003 | 08:15 PM
EG6-SiR's Avatar
New User
Default Re: good oem brakes on a eg (turbosol)
bb prelude brakes are all good cost effective oem upgrade
Old Apr 26, 2003 | 05:06 AM
wm5holla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosol &raquo;</TD></TR><TR><TD CLASS="quote">I perfer the ITRs, my friend had a gsr with brembo cryo treated cross drilled rotors, goodridge lines, and a number of differrent pads and the braking force never came close to my stock ITR brakes.</TD></TR></TABLE> will itr fit on a 4 lug tho?
Old Apr 26, 2003 | 08:55 AM
MAD ITR 55's Avatar
No,you need to convert it over to ITR 5-lug.Beleive me its worth it.
Old Apr 26, 2003 | 10:14 AM
GetawayInMoscow's Avatar
Default Re: good oem brakes on a eg (V8s2shame)
How big are you wheels? You could get a Wilwood kit cheaper than ITR 5 lug and it would stop better too.
Also look at
http://www.fastbrakes.com
Old Apr 26, 2003 | 12:05 PM
wm5holla's Avatar
Default Re: good oem brakes on a eg (GetawayinMoscow)
naw . i wanted to stay oem.. i was think GSR rotors ans pads would be bigger that 92-95 brakes, oh i got rear disc brakes too
Old Apr 26, 2003 | 12:41 PM
kommon_sense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">theyre the same size</TD></TR></TABLE>
they are the same size as the EX front rotors, but they are just over an inch bigger in diameter than the other lower model civs.
If you already have an EX, then you have the biggest rotors that you can get unless you go with an ITR setup. If that is the case, then you should look into getting some good brake fluid, and a good set of brake pads.
Old Apr 26, 2003 | 02:14 PM
wm5holla's Avatar
Default Re: good oem brakes on a eg (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense &raquo;</TD></TR><TR><TD CLASS="quote">
If you already have an EX, then you have the biggest rotors that you can get unless you go with an ITR setup. If that is the case, then you should look into getting some good brake fluid, and a good set of brake pads.</TD></TR></TABLE> are gsr pads better than civic what is good fuild too
Old Apr 26, 2003 | 02:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote"> are gsr pads better than civic what is good fuild too</TD></TR></TABLE>
the quality of the pad has nothing to do with what car it is for. Do a little research on aftermarket pads. A lot of people are happy with aem pads and axxis ultimate pads for street purposes.
As for fluid, I'm sure that everyone will agree. Either ATE Superblue Racing or ATE Type 200. They are the exact same thing, except one is blue, while the other is gold colored. You can order it online from http://www.ogracing.com .
Old Apr 29, 2003 | 10:35 AM
jdmIScool's Avatar
are the gsr and the ex brake setup the same.....which is better......is the piston size the same on the calipers......
vtec95
Honda S2000
Jan 21, 2008 02:18 PM
poormans_typer69
Jan 11, 2008 03:24 PM
tony n.
Jun 16, 2007 07:18 AM
eg4life1202
Oct 26, 2006 08:50 AM
Blindstuff
24
Jan 5, 2004 06:29 AM
