can you take off the knock sensor and still run your motor ok?
Old Apr 25, 2003 | 03:39 PM
hatchboy93
Guest
Posts: n/a
Default can you take off the knock sensor and still run your motor ok?
ok my friend has a gsr motor and he said since hes runnign a chipped p28 and doesnt need the knock sensor i could have his. can i take his off and leave it off and not replace it on his motor? i mean will it hurt his motor if theres not a actual knock sensor on his motor??
Old Apr 25, 2003 | 03:46 PM
RSZero1's Avatar
Default Re: can you take off the knock sensor and still run your motor ok? (hatchboy93)
if he's running a p28 he wont need it, since the p28 doesnt look for that particular sensor. However if you remove it from a car that does use it, it will mess up your timing and performance will be like crap....
<----RSZero1 is unhappy his KS is still not wired up, but will have it done tomorrow....
EDIT: learned this the hard way....
Old Apr 25, 2003 | 03:50 PM
IS3Fifty's Avatar
Default Re: can you take off the knock sensor and still run your motor ok? (RSZero1)
knock sensors are there for a reason... if you can still use it and theres use for it then use it
Old Apr 25, 2003 | 03:58 PM
hatchboy93
Guest
Posts: n/a
Default Re: can you take off the knock sensor and still run your motor ok? (TODAeg6)
well he doesnt need it cuz he has a p28 chiped but i need it because i have a gsr ecu p72. but wil his motor be ok if i physically remove it from his block and not put something there in its place?
1sikhatch
Aug 17, 2010 08:20 AM
iLovPhoKing
Mar 17, 2005 08:07 AM
eda6
Oct 8, 2004 03:54 AM
roc
Mar 29, 2003 04:28 AM
B20-T
Feb 19, 2003 06:39 AM
