camber kit
Old Apr 25, 2003 | 02:04 PM
HatchBox's Avatar
Skoobie no more...
Default camber kit
will a camber kit off a 93 civic work on my 1990 civic hatch?
Old Apr 25, 2003 | 02:32 PM
Camshaft's Avatar
Default Re: camber kit (rsk436)
hey man help us out what kind of kit ?
there are a number of kits in the market
From complete upper control arms to replacement upper ball joints to ingals style inner pivots.
I would say that most stuff doesn't swap from 91 to 92 that is the body style jump but anything is possible...
cheers
good luck cam
Old Apr 25, 2003 | 02:58 PM
HatchBox's Avatar
Skoobie no more...
Default Re: camber kit (Camshaft)
i would love too...but this is all the info i have gotten ..
http://forums.clubsi.com/showf...21377
Old Apr 25, 2003 | 04:16 PM
HatchBox's Avatar
Skoobie no more...
its a ingalls ...here is a pic...75 shipped ...what do u think?
Old Apr 25, 2003 | 07:44 PM
91 Civic B16's Avatar
i put a set of those on my '91 civic. they work ok, but my car is so low that if i adjust them so the wheels are straight, the upper A arms rest on the wheel well and stop the suspension travel. i think that can be fixed with a sawzall, lol.
Old Apr 25, 2003 | 08:09 PM
Camshaft's Avatar
Default Re: camber kit (91 Civic B16)
so you want to put these on your 93 Civic?
I have a set of ingals on my 91 CRX and they squeak like hell ....
not very impressed at all.....
You do have to cut out the inner fender area to make clearance
Old Apr 25, 2003 | 08:50 PM
HatchBox's Avatar
Skoobie no more...
hmmm i just looked at there website and they said they would fit...which ones squeek the rubber bushings or plyurethane?
Old Apr 25, 2003 | 09:00 PM
i hear the polyurethane lasts longer, but are loud. Rubber is quieter, but dont last as long.
Old Apr 25, 2003 | 09:23 PM
HatchBox's Avatar
Skoobie no more...
what happens when the rubber wears out?
Old Apr 25, 2003 | 09:59 PM
nothing really major, you should have them checked and replaced if they are bad.
Old Apr 25, 2003 | 11:20 PM
FR-MOB: ThE bEe GuY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Camshaft &raquo;</TD></TR><TR><TD CLASS="quote">so you want to put these on your 93 Civic?
You do have to cut out the inner fender area to make clearance</TD></TR></TABLE>
You gotta grease the camber kit every once in a while to keep it from squeeking.
But Oh well, yay i just ordered my Ingalls with Poly bushings..FINALLY!
Old Apr 26, 2003 | 05:58 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: camber kit (ThE bEe GuY)
i second, i have progress kunckle style kit, with polly bushings, and at first it squeaked, so i backed them off, and used locktite, and all gone..
think about it though, you dont' wanna squeze it in, you just want the bolt to ride on that bushing.. you don't need to sqeaze it.
Old Apr 26, 2003 | 06:54 AM
Camshaft's Avatar
Default Re: camber kit (Built B16A)
You are correct ingalls listing says 91 and 93 civic uses the same part
you should be ok
I have the rubber style in my car and it squeaks
If the rubber wears out..... by a hole new ingall unit
I'm taking out my ingals and putting in these adjustible ball joints very slick
fatsalmon15
Sep 28, 2013 01:38 PM
wood
Dec 28, 2005 12:02 AM
Sandor
Nov 17, 2003 09:01 AM
ZERO COOL
Oct 18, 2002 03:43 AM
