HELP! Something really bad happened! AGG!! Need help ASAP!!!
OKay, i dont know how vital this is, but im pretty sure it is. I was just gently pulling these out to clean some oil off the valve cover, and BAM, this part just came out. It looks like the wires got ripped or something and the plastic piece thats long and goes over the sparkplug stayed in the hole, and when i try to take it out, it comes out but the little metal piece stays in there! Where can i find a new one of these? What will it do being ripped? ANd how much will it cost to fix! Please help with any info ASAP! Thanks!
just time to replace your plug wires, if you can get the boot off just pull the plug and use something to grab the metal piece and put the plug back in.
Alright, where do i get plug wires? I dont know much about the spark plugs and what not? Can i pick some new plug wires up at say a autozone or something? Its safe to drive my car like this correct or no? Thank you so much!
I was worried another bad thing would happen to me, haha sometimes i seem to have bad luck, last time it was getting stopped for doing 35 in a 30! jesus lord. !
Alright, so what exactly broke? I just need one, the other ones are fine.. this really sucks.. is it going to be bad to drive my car like this tho? How much will a "set" run me? Also, is there really a quality diff between brands, like will i lose or gain performance depending on what i buy? So when i go into autozone, what should i ask them for? Thanks!
that little wire is what is kinked in the little metal piece. ya cant just buy one so ya have to get a full set, cheep ones will be about $17 from auto zone. just look at the size and try to get an 8mm or 7mm wire. wont be as good as some other wires but it will get you by. what motor is that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPASSBEOTCH »</TD></TR><TR><TD CLASS="quote">dont go to auto zone their ignition parts are ****...go to a napa store and buy belden wires...they have a liftime warranty and they are not that much more.
oh and use dielectric grease on the wires .just a little bit in the end of the spark plug boot .that way next time you pull them off they probably wont stick to the plug and break.
yea good idea, try napa autozone does suck,
oh and use dielectric grease on the wires .just a little bit in the end of the spark plug boot .that way next time you pull them off they probably wont stick to the plug and break.</TD></TR></TABLE>
Aight, ill go to napa, my engine is a DOHC ZC engine. Ill bring what i got over to them, should i just put the rubber part back on, head over to napa and get new wires? How do i need to wire these things up? Any more info would be great! How much will a good set run me! Thanks
i wouldnt drive your car. carry all the plus wires and i think some for the 90-92 integra ls plugs will work. carry them in and compare. but make sure to mark your dist cap which plug went where. i take it your not to mechanicaly inclined?
Actually im not mechanically inclined in some parts, but in others, i just dunno whats going on, i know some complex ****, but some really simple stuff boggles my mind sometimes. LOL. Would Advanced auto parts have these parts, the good ones? they are right down the road!
edit: LOL i put i was mechanically inclined, okay, my brain has shut off for today.
Modified by GroundZer0 at 5:42 PM 4/25/2003
well if they're just down the road, why not check, lol.
i bought my wires for $30 canadian, so around $20 american. akthough they're supposed to be a pretty good quality set, i work at the store so i know most of the lines there.
Jose-aka-Pedro
Nov 2, 2006 08:28 PM
freeplay
Oct 27, 2002 08:27 PM
94integrablur
Apr 24, 2002 02:46 PM
