is there a way to use the automatic d16y8 intake manifold and TB?
Old Apr 25, 2003 | 12:18 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default is there a way to use the automatic d16y8 intake manifold and TB?
was there a way to use the automatic d16y8 intake manifold and TB on a d16a6? i remember seeing a thread about it but i cant find it.
the eacv is on the TB and has 3 wires...vs the manual tranny version with the 2 wire eacv on the back of the manifold. i thought that you just had to ground one of the eacv wires but am not sure. thanks for the help.
Old Apr 25, 2003 | 12:41 PM
Lord Quaalard's Avatar
Default Re: is there a way to use the automatic d16y8 intake manifold and TB? (fastcrxsi90)
I am doing exactly that this weekend (no more putting it off) and will be writing a how-to. It involves some drilling and tapping, but if that doesn't bother you, keep looking. It will probably be in the D-Series information post and mirrored on my website currently under construction. Keep you pants on.
Old Apr 25, 2003 | 01:33 PM
zCivic's Avatar
Default Re: is there a way to use the automatic d16y8 intake manifold and TB? (Lord Quaalard)
yep drill and tap so that it can accept a IACV from a 92+ civic/integra or anything that uses the small bolt pattern....that why I always suggest the A/T even if its a little higher $$$ you've got it ready to go and don't have to look or buy another IACV, IMO
Old Apr 25, 2003 | 04:41 PM
ShiroX's Avatar
Default Re: is there a way to use the automatic d16y8 intake manifold and TB? (zCivic)
why do you need to drill and tap to use another IACV? whats wrong with the automatic one?
Old Apr 25, 2003 | 05:16 PM
EG8R's Avatar
Default Re: is there a way to use the automatic d16y8 intake manifold and TB? (VTeC4TheChildren)
Its located in the TB. I believe its a 3 wire instead of 2....
Old Apr 25, 2003 | 07:08 PM
Default Re: is there a way to use the automatic d16y8 intake manifold and TB? (mr. skelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. skelly &raquo;</TD></TR><TR><TD CLASS="quote">Its located in the TB. I believe its a 3 wire instead of 2....</TD></TR></TABLE>
yeah...i thought i read something about hooking the 2 wires to the ecu and just putting one to ground and it would work. but i cant remember, and id rather find out before i drill and tap the **** out of it.
Lordofdark176
Oct 13, 2008 06:46 PM
SRCivic97
Jul 13, 2005 11:30 PM
lilcasino
Nov 10, 2004 12:06 PM
d16rice
Oct 5, 2004 06:04 PM
