power windows on crx
ok. im sure that i am not the only Crex owner to realize that we here in the USDM realm got jipped out on the cool **** that can be found in the JDM one. from the front end and stuff, to the hood with the scoop, to the coolest thing that pisses me off..... POWER WINDOWS. is there and USDM conversion know that can solve this delema?!!!! also, JDM gets an uncomfortable smushy rear seat. it looks hella cool though.
bump for honda-tech and the honest users
i know u said USDM conversion, but u can easily find a JDM power window kit on ebay. installation is really easy, its just the wiring that takes a little bit of time. I got a JDM kit off ebay, and i like it alot. I think someone also mentioned before that CRX/EF's in Canada, one of the models had optional power windows. Search around some more, but i hope this helped a little.
Ya, but think about it... all the main controls for the power windows would be on the passenger side since that is the drivers side in JDM Land... so the driver would still have to lean over to do everything... unless you make a custom panel or something on the new driverside panel, you know what I mean?
haha, yeah. i have one switch on the driver side and the dual switches on the pass. side but only one of them is hooked up on that side. I dont mind leaning over everytime i need to open the pass. side window. I just have to hit the button rather than turning the window crank manually. so no big deal. The other alternative is to find another dual switch, and have them on both sides....but yeah, i like my power windows.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crew08 »</TD></TR><TR><TD CLASS="quote">i have a set of usdm switches , i never used it cause i modified a set where my ebrake is. how much are they worth anyhow?
that's what i have thought about doing- having just 2 switches in the center & nothing in the doors. you'd just have to put some tweeters or something in the door to fill the crankholes.
USDM Switches? no cr-x's came with power windows here in the us. how do you have USDM switches?
not sure about you guys but up here in Canada we got them as a option on all Civics and crxs............did i mention i have them and boy do i love them!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitekidsef9 »</TD></TR><TR><TD CLASS="quote">not sure about you guys but up here in Canada we got them as a option on all Civics and crxs............did i mention i have them and boy do i love them!!!!</TD></TR></TABLE>
lucky *****, whats your address? Just out of curiosity of course.
j/k
EDIT: the guy with USDM switches might have got them out of the 88-91 4dr sedan EX that has power windows.
j/kEDIT: the guy with USDM switches might have got them out of the 88-91 4dr sedan EX that has power windows.
I managed to find a 88-89 CRX or Civic with a OE Honda Power window kit. Very slick !!!!!
Picked up door panels, window regulators with motors, all wiring, switch etc..
Really cool the honda kit just plugs right into the main harness under the dash.
HHHaaahha Added bonus it has Auto up and Auto Down !!!
and its North American so none of this 2 button bullshit on the passengers side
Will post some pics
cheers
happy hunting
cam
Will post some pics
cheers
happy hunting
cam
All of you ppl with the JDM power windows, you can flip the swithces over and put it so that the two are on the driver side and the one is on the passenger side. The lettering will bu upside dow, but just remove the stickers and fix that if it bothers you. Whala, no more leaning over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant »</TD></TR><TR><TD CLASS="quote">All of you ppl with the JDM power windows, you can flip the swithces over and put it so that the two are on the driver side and the one is on the passenger side. The lettering will bu upside dow, but just remove the stickers and fix that if it bothers you. Whala, no more leaning over.</TD></TR></TABLE>
i thought it was that easy also, but if u switch sides, you'd have to cut the hole bigger for the driver side, which isnt that bit of a deal. The problem is the passenger side, the whole switch/handle is like an inch shorter, and its a lot of work to fill in that hole. thats just from my experience.
I've got the window motors from a 90 civic LX and all I had to do was swap the "rails" from the stock manual regulator. I also have very basic switches from the rear doors of a 94 hundai elantra. they're also illuminated when the headlights go on! All of this is tucked under my e-brake cover, can't see it from the outside but bother driver and passanger can use the switches.
surprisingly enough, the electric assemblies bolt up to the USDM door skin using different holes then the manual ones.
I was pleasantly surprised. hands down one of the best "mods" I've done to my car in the past 6 months.
~Alex
~Alex
i guess i dont understand what all you are doing. can i leave my stock door panel on, change the manual stuff to power stuff, and just put the window buttons by the ebrake cover or something? b'c i love my 'si panels. thanks for all the follow ups on the post.
Here's what I did:
Purchased JDM Power Windows on eBay.
Using my CRX Si door panels, I cut the holes on the doors a bit larger for the window controls. I put the main controls on my drivers side (just flipped it upside down). Replaced the regulators inside the doors with the JDM ones. Figured out the wiring using the JDM Mechanics Manual that was found the the web (i forgot the url). and now everything is powered. The only feature that doesn't work the the auto up/down.
I'll take some pictures as soon as I can.
I would like to see pictures.......
As the JDM controls can't just be flipped as some people say......
The housing that holds the switch isn't square.......
But if you have time and some body filler anything is possible......
later
cam
later
cam
Yes come Canadian CRXs had power windows as an option, but for some reason they were like a $500 option at OEM starting. If you cant find CDM ones you can go for JDM ones if you dont mind going over to open the passenger window. But there is a third option that not too many people exploit. In some European countries CRXs were right hand drive but they were filled with all the JDM goodies. Including power windows on most models. The wiring and switches are on the correct side for USDM use. I hope this helps.
CRX Forum
CRX Forum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Camshaft »</TD></TR><TR><TD CLASS="quote">or you can just get a aftermarket kit that has a number of different switch like spal</TD></TR></TABLE>
I have the Spal kit in my hatch and I love it!!! I got the 2-switch kit and mounted the switches in the stock knockouts of my '99 Teg center console.
From: hittin corners so hard you can taste my rims..
CRXSi_AutoX... i just looked at your website, or crap for sale... 980 for a SiR conversion? god damn... hows your sales..? 100 bucks for some JDM folding mirrors? i'll take 10 sets.. woah you prices are off the wall.
Ok guys got tired of bla bla talking with no pics
JDM power switch assembly
JDM close up shot
As you can see the switch assembly isn't square so you can't just pop it out and reverse it etc
Passengers side of my car CND model with modified no lock assembly and LED
Door crank plug
Drivers side of my car CND model with modified no lock assembly and LED
excuse the crappy carbon fiber sheet..... cheap *** ractive stuff
JDM close up shot
Door crank plug
