'92 Teg Question
I'm looking for specifications for the 1992 Integra GS-R. If anybody knows where I can find a spec sheet or something like that, please let me know.
Thanks,
Jim
Thanks,
Jim
Thanks. Unfortunately, I can't find anywhere where they list the specs for the GSR.
Did I miss it, or is there anywhere else I can find it?
GS-R
Engine Type
1.7L, DOHC, 4-cyl., 16-valve with Variable Timing & Lift Electronic Control (VTEC) System
HP, SAE net
160hp @ 7600 rpm
Torque
117 lbs-ft (16.2kg-m) @ 7000 rpm
Redline
8000 rpm
Bore & Stroke
3.19 in x 3.20 in
(81mm x 81.4mm)
Displacement
102.4 cu in (1678 cc)
Compression Ratio
9.7 : 1
Alternator
12V, 80 Amp. Max.
Induction System
Programmed Fuel Injection (PGM-FI)
Engine Block
Aluminum Alloy with Cast-Iron Cylinder Liners
Cylinder Head
Aluminum Alloy
Emission Control
3-way Catalytic Converter
Ignition System
Fully Transistorized
Drivetrain
Traverse Front Engine / Front-wheel Drive with Equal-length Halfshafts
Transmission Ratio (:1)
1st
3.307
2nd
2.105
3rd
1.458
4th
1.107
5th
0.875
Reverse
3.000
Final Drive
4.400
..There's more info on g2ic, but I'm too lazy to cut and paste today
Engine Type
HP, SAE net
160hp @ 7600 rpm
Torque
Redline
8000 rpm
Bore & Stroke
3.19 in x 3.20 in
(81mm x 81.4mm)
Displacement
Compression Ratio
9.7 : 1
Alternator
12V, 80 Amp. Max.
Induction System
Engine Block
Cylinder Head
Aluminum Alloy
Emission Control
Ignition System
Drivetrain
1st
3.307
2nd
2.105
3rd
1.458
4th
1.107
5th
0.875
Reverse
3.000
Final Drive
4.400
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bravenrace »</TD></TR><TR><TD CLASS="quote">Thanks. Unfortunately, I can't find anywhere where they list the specs for the GSR.
If you can't find it on that page, then I can't help you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92JDMGSR »</TD></TR><TR><TD CLASS="quote">I have a B17 for sale if thats what you are looking for.</TD></TR></TABLE>
He has alot of goodies in that motor
