ITR guy with prelude injector question
I need some injectors that will support 240 whp at 85% duty cycle with max fuel pressure of 75 psi. Will the 290's handle that? If not then how close? I could stand a little higher fuel pressure because my car is not for the track and is not pushed to its limits for any extended periods of time.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM LUDE »</TD></TR><TR><TD CLASS="quote">I suggest buying my 4th gen 330cc injectors that I have laying around
He can't use those. 4th gen Preludes use Peak and Hold injectors. 5th gen Preludes, Integras, and almost all other Hondas use saturated injectors.
Andrew
</TD></TR></TABLE>He can't use those. 4th gen Preludes use Peak and Hold injectors. 5th gen Preludes, Integras, and almost all other Hondas use saturated injectors.
Andrew
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aklucsarits »</TD></TR><TR><TD CLASS="quote">
Andrew</TD></TR></TABLE>
Thanks, man. I was just doing some research on that. I should have known to ask. Do you know if the 290's are big enough for what I need?
caliprelude3087
Nov 18, 2004 01:27 PM
