Upgraded Rotors!!!?!???
Old Apr 24, 2003 | 06:45 PM
BlackNoise's Avatar
Default Upgraded Rotors!!!?!???
Anyone know which would be better to get, cross-drilled rotors or just slotted or neither? I'm mainly looking for one that will last the longest and not warp or crack. I have considered getting brembo cross-drilled/slotted rotors, but started to hear that they are unsafe and aren't as good as blanks? I really want to get some new rotors quick b/c my rotors are warped and my brakes suck. Which are the best? Should I go with brake lines, pads and rotors...either or what? Help!
Old Apr 24, 2003 | 06:47 PM
IM ALL BOB's Avatar
Default Re: Upgraded Rotors!!!?!??? (BlackNoise)
go with brembo or autozone blanks... axis ultimate pads..ATE brake fluid.. and if u want some goodridge or earl's brake lines.. even a simple M/C upgrade with just pads and fluid will make a night a day difference from your stock setup good luck
Old Apr 24, 2003 | 06:57 PM
BlackNoise's Avatar
Default Re: Upgraded Rotors!!!?!??? (IM ALL BOB)
what about the axis metal master pads? are those worth the trouble?
Old Apr 24, 2003 | 09:07 PM
kommon_sense's Avatar
get blanks. don't waste the money on slotted. They warp just as easily as blanks and cost 3 times as much. I just replaced both of my front warped slotted rotors with a set of brembo blanks. Good pads, ate brake fluid and you will be happy.
Old Apr 24, 2003 | 09:34 PM
clm's Avatar
clm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IM ALL BOB &raquo;</TD></TR><TR><TD CLASS="quote">go with brembo or autozone blanks... axis ultimate pads..ATE brake fluid..</TD></TR></TABLE>
That's what I have and I love it. But just get some blanks and a decent set of pads from AutoZone if you're on a budget - otherwise get some ATE fluid and Axxis pads.
Old Apr 24, 2003 | 09:46 PM
VTHokie's Avatar
Default Re: Upgraded Rotors!!!?!??? (clm)
don't get crossdrilled. They have been known to crack.
Old Apr 24, 2003 | 10:39 PM
D16Z6racing's Avatar
Default Re: Upgraded Rotors!!!?!??? (VTHokie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTHokie &raquo;</TD></TR><TR><TD CLASS="quote">don't get crossdrilled. They have been known to crack. </TD></TR></TABLE>
Never heard that before. I've been running Brembo crossdrilled on my EH for a year. No problems. Brembo crossdrilled or slotted rotors aren't going to warp, they'll just wear down, probably create a lip at the edge of the rotor. The only dissadvatage to C/D or slotted is they can't be resurfaced.
I just replaced my rotors w/ Brembo blanks. They work great as well, and a whole lot cheaper.
Old Apr 25, 2003 | 06:46 AM
Default Re: Upgraded Rotors!!!?!??? (D16Z6racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing &raquo;</TD></TR><TR><TD CLASS="quote">
I just replaced my rotors w/ Brembo blanks. They work great as well, and a whole lot cheaper.</TD></TR></TABLE>
cheap crossdrilled rotors can crack and quality crossdrilled have been known to crack under extreme conditions. Yes, slotted rotors will warp just as easily as blanks. I just took a warped set of slotted rotors off of my car a few weeks ago. I am now running on brembo blanks which brake every bit as good as the slotted rotors did before they warped.
Old Apr 25, 2003 | 06:50 AM
jolt-tsp's Avatar
Default Re: Upgraded Rotors!!!?!??? (kommon_sense)
From what I've heard, just get blanks unless you want to drop $2-4k down on some 4-piston calipers and slotted rotors. If you wanna do that, check out stoptech, I've heard only good things about them. Brembo's good too, but about 2 times as expensive.
Old Apr 25, 2003 | 07:48 AM
SloCivicHMM's Avatar
Yes they can...take them to a flywheel and clutch shop....they can be resurfaced teh same way a flywheel is lighten'd or just resurfaced......I did mine.....works great!!
Old Apr 25, 2003 | 08:01 AM
clm's Avatar
clm
Default Re: Upgraded Rotors!!!?!??? (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">just get blanks unless you want to drop $2-4k down on some 4-piston calipers and slotted rotors. </TD></TR></TABLE>
That estimate is a bit exagerative - atleast if you're talking about the Wilwood kit.
Old Apr 25, 2003 | 08:02 AM
cre18's Avatar
brembo blanks and i would suggest getting some performance pads. when i had stock civic brakes on my hatch i swapped the pads for a set of porterfield r4s's and they made a hug difference, althouth the downfall is that performance pads will dust a lot more than stock pads. also try using some dot 3 or 4 brake fluid, like motul or ate. for added braking power look into swapping out your master cylinder and brake booster with an 99-00si or integra.
Old Apr 25, 2003 | 08:13 AM
EKhothatch's Avatar
Brembo blanks are what I'm running, I am doing a brake job (still in the process) and I have Brembo blanks, AEM pads, Goodridge stainless lines all the way around w/ DOT 4 fluid. I haven't got a chance to test it out yet, cause I'm having a problem with the rear calipers bolting up.
Old Apr 25, 2003 | 11:46 AM
Default Re: Upgraded Rotors!!!?!??? (inline4hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inline4hatch &raquo;</TD></TR><TR><TD CLASS="quote">Brembo blanks are what I'm running, I am doing a brake job (still in the process) and I have Brembo blanks, AEM pads, Goodridge stainless lines all the way around w/ DOT 4 fluid. I haven't got a chance to test it out yet, cause I'm having a problem with the rear calipers bolting up.</TD></TR></TABLE>
You will like that setup I'm running the same just no ss lines and I'm very happy with it.
Old Apr 25, 2003 | 11:47 AM
jolt-tsp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clm &raquo;</TD></TR><TR><TD CLASS="quote"> That estimate is a bit exagerative - atleast if you're talking about the Wilwood kit.</TD></TR></TABLE>
Nah, I'm talking about Brembo F50's or StopTech
Old Apr 25, 2003 | 12:54 PM
BlackNoise's Avatar
aight thanks fellas i'll spread the word.
98-blackhatch
Suspension & Brakes
13
Dec 11, 2014 08:59 AM
MILANO_RED_CL9
Acura TSX
10
Sep 29, 2010 04:58 AM
MILANO_RED_CL9
Suspension & Brakes
Sep 17, 2010 11:08 AM
dragonkx
13
Jun 29, 2010 07:37 AM
erniecars
Jul 11, 2002 08:35 PM
