koni yellow with stock springs
Old Apr 24, 2003 | 02:50 PM
itrboi's Avatar
Default koni yellow with stock springs
are you guys using the koni with the stock springs? and if so how high does your koni yellow with stock springs ride because my rear rides pretty damn high and i dont know how to lower it. the rears are internally adjustable and i dunno how to adjust it.
help me please!
Old Apr 24, 2003 | 02:57 PM
92TypeR's Avatar
FSAE
Default Re: koni yellow with stock springs (itrboi)
I love my setup. Revalved Yellows and stock springs.
Ride height is approx. 1/4" lower than normal ITR ride height.
Don't know why it would be any different for yours.
Old Apr 24, 2003 | 03:04 PM
itrboi's Avatar
Default Re: koni yellow with stock springs (92TypeR)
is it cuz i installed in wrong because it rides way higher then normal
the wheel gap is like 6 inches
Old Apr 24, 2003 | 04:41 PM
Alexander's Avatar
make sure your koni yellows are set to the stock ride height "perches".. you should have 3 choices in the back (pick the middle one) and I think 2 in the front (pick the higher one).. good luck!
-Alex
Old Apr 24, 2003 | 07:57 PM
itrboi's Avatar
Default Re: koni yellow with stock springs (AVD23)
aite thanks
Old Apr 24, 2003 | 08:12 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">I love my setup. Revalved Yellows and stock springs.
Don't know why it would be any different for yours.</TD></TR></TABLE>
Do you have a lot of roll with this setup on a track?
Old Apr 25, 2003 | 12:18 AM
92TypeR's Avatar
FSAE
Default Re: koni yellow with stock springs (FrostyDC4)
The shocks wont help out body roll tremendously, but I think they did a good job. The car definately feels more planted, especially around higher speed turns (70-80mph), and I have them set at full stiff on all four for lapping days.
I highly reccommend this setup to someone who can't afford the higher end peices out there (TEIN RA/HA, Endless S6/B6, Buddy Club...).
Old Apr 25, 2003 | 04:17 AM
bbqman's Avatar
I just put my Koni 2 way adjustable, revalved dampers on the stock springs and ran at Expo. I was damned impressed....no body roll and the ride height is stock...if you use the middle setting for the perch.....it has to to be D/S legal.
BTW, the Mugen RSX and the Coletti cars had nothing on me thru the carousel section of Beaverun when I waved them by into turn 1....I was freaking at how the car stayed settled......after the drop-off section however, it was a another (sad) story.....bye bye Mugen etc.......those cars are wicked fast.........
Anyways....Koni yellows
Old Apr 25, 2003 | 04:22 AM
DutchITR1689's Avatar
I have the euro version of the KONI's with stock springs. They are very good indeed...
Old Apr 25, 2003 | 07:36 AM
shivers's Avatar
Default Re: koni yellow with stock springs (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
There might also still be a problem with big US suppliers selling the CRX shocks for the ITR. Those shocks only have a single spring perch, and it's not in the absolutely perfect position.
Research the part numbers and make sure they're sending you the right ones.
George. &lt;-Who is still paying the price for not researching carefully and just taking a large supplier's word for it.</TD></TR></TABLE>
Thanks for the heads-up, George. I'm in the market for some Konis and I'll definitely be checking part #s.
Old Apr 25, 2003 | 07:50 AM
bbqman's Avatar
Default Re: koni yellow with stock springs (ajm_00Si)
Yup, George is right and only until recently did they supply the externally adjustable ITR specific rear shocks.
Btw, I set them at Beaverun at 1/2 from full front and 2/3 to full rear damping and only 1 click up from full soft on the compression damping...it was enough and again those who rode with my thought I had a coil over setup.........nope...yellows (revalved) on stock springs........so nice
If I can help, let me know......it is all fresh in my mind.
Old Apr 25, 2003 | 09:15 AM
92TypeR's Avatar
FSAE
Default Re: koni yellow with stock springs (bbqman)
The shocks can lock up when on full stiff? I was not aware of this
And yes, mine are externally adjustable.
Old Apr 25, 2003 | 10:38 PM
itrboi's Avatar
i reinstalled my front right shock because it was knocking everytime i hit a bump and after reinstalling it i got the knocking to go away but now the right side sits like an inch higher then the left side. does anyone know wut i did wrong?
Old Apr 26, 2003 | 02:15 AM
igotyofire's Avatar
do u think it would be wise to try this setup with my 2000 Civic Si, i know it wont handle as good as a type R tho...
Old Apr 26, 2003 | 04:40 PM
PY2KITR1060's Avatar
Hi George, can you clarify more? Now i'm a bit worried since i ordered the following just couple days ago:
8041-1152 SP3 (Neuspeed series) for front
8041-1164 Sport for rear (the new externally adjustable ones)
Would this new rear shocks have the problem that you mentioned?
Also this would go on with h&r sport spring....
Also, is the above 2 way adjustable (both compress and rebound?). The koni website seems to says rebound adjustable only?
Big Dog
Apr 16, 2009 07:21 PM
dpine
Suspension & Brakes
Sep 3, 2008 07:44 AM
ac_attak
Oct 26, 2006 07:01 PM
t_c_l_6
Suspension & Brakes
Mar 19, 2006 05:29 PM
