Not quite type r...yet need your help (please)
Old Apr 24, 2003 | 12:29 PM
mr_ben's Avatar
Default Not quite type r...yet need your help (please)
I have a B18C JDM engine out of a Teg Si in a JDM ITR (long story don't ask!!)
I'm sourcing a Skunk 2 Intake manifold (from the US) to improve air flow and BHP, but I have a few questions.
Because I'm from the UK people here haven't heard of Skunk2 stuff properly yet so their knowledge is a bit ropey!!!
I would like to know if:
a: With the Skunk2 Intake Manifold on can I use a Spoon Throttle body
b: With the above mentioned do I then technically use a standard fit ITR Air
Forced Intake (Mügen) or what???
c: Is there anything else I need to consider???
Thanx guy I know you'll be able to help
Old Apr 24, 2003 | 01:27 PM
Cosworth's Avatar
Default Re: Not quite type r...yet need your help (mr_ben)
Isn't Skunk2 intake manifold an exact copy of the ITR manifold? So, Spoon TB should fit without a problem, as far as I know.
Old Apr 24, 2003 | 01:34 PM
Gong Show's Avatar
Default Re: Not quite type r...yet need your help (Cosworth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cosworth &raquo;</TD></TR><TR><TD CLASS="quote">Isn't Skunk2 intake manifold an exact copy of the ITR manifold? So, Spoon TB should fit without a problem, as far as I know.
Yep, thats exactly what it is. So any TB will/should work with it. But you might wanna port match it(dont know if needed but might help).
Also you will need a ITR type intake since the GSR intake curls under. You might have to modify your throttle cable aswell. I cant remember. I've had mine on for two years now.
Old Apr 24, 2003 | 01:48 PM
Philly_NBP_R's Avatar
Default Re: Not quite type r...yet need your help (Gong Show)
JG / Edelbrock intake manifold would work too. Get that, ITR / spoon throttle body, and an AEM (for ITR), and your'e good to go
Old Apr 25, 2003 | 01:28 AM
mr_ben's Avatar
Default Re: Not quite type r...yet need your help (Philly_NBP_R)
Thanks for your help guys much appreciated. And yes I will be getting the internals up graded and matched!! Spoon gear here we come!!!
Boyle.R
Jan 24, 2013 01:32 AM
BAMA4792
Jul 27, 2007 05:12 PM
hmgemperor2003
Jul 9, 2007 02:59 PM
LD_EGSICK
25
Jul 31, 2003 08:30 PM
mr_ben
Apr 25, 2003 01:29 AM
