96 hatch syncros/steering
My stick has gotten sloppier over the past few years and i think putting new syncros will solve the problem. Any advice? I already took a quick look and down by the gas peddle is where it looks like ill have to start tearing it apart. Should i order the syncros from honda or is there another source and how difficult is the install?
2nd i got the pure base model ( not even ac but i installed it later houston is too hot ) without power steering for future motor swap possiblities, and the steering at low speeds is well shitty. The wheel turns way too easily and i have to turn it 3 damn times to do a u-turn, any help appreciated thx.
what do you mean by sloppy? does it grind or just feel loose? if it just feels loose try changing out the stock shift linkage bushings for polyurathane ones from energy suspension (only 10 bucks), that will stiffen it up a bit.
Eee Kayyy
Apr 16, 2019 09:58 PM
808HAYN
Feb 29, 2012 11:17 AM
