WTF is wrong with my front end???
Old Apr 24, 2003 | 08:44 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default WTF is wrong with my front end???
Well lately my car has been vibrating when i turn right. Its like something isnt balanced right. I thought that it was the wheel so i put on another set and it still does it. Now it does it when i turn left and im turning the wheelback right to straighten up. And its like once it starts vibrating it will keep doing it until i change gears...even if i punch it. Its the most anoying thing in the damn world. It did it a little when i first did the swap(b18 in a crx)...then i got in a little accident and hit a curb and it has slowly gotten worse since then. And my alignment is off a little...not too bad. The car goes pretty straight but my steering wheel is turned left all the time now. I want to get it fixed before i get it aligned. It seems to do it worse when its cold for some reason. Thanks
Sean
Old Apr 24, 2003 | 09:41 AM
cyberx's Avatar
Default Re: WTF is wrong with my front end??? (sCeRaXn)
check the axles, are they spittin up grease, i had a similar problem, but not exactly the same symptoms....
Old Apr 24, 2003 | 09:47 AM
sCeRaXn's Avatar
Default Re: WTF is wrong with my front end??? (cyberx)
I know its not the axles...well its not the CV joint anyway. I really need to get this fixed. Thanks.
Sean
Old Apr 24, 2003 | 10:53 AM
altoid's Avatar
could be you need an alignment...go for that and see if it stops
Old Apr 24, 2003 | 03:29 PM
dreweg's Avatar
Default Re: WTF is wrong with my front end??? (altoid)
Anyone else have any opinions?
Sean
Old Apr 24, 2003 | 05:38 PM
slowcarguy's Avatar
Default Re: WTF is wrong with my front end??? (dreweg)
Wheel hub bearings perhaps? I know I need to replace my left front one and there's significant play in the wheel...scary!
~Alex
Old Apr 24, 2003 | 07:07 PM
thevtecnician's Avatar
Default Re: WTF is wrong with my front end??? (slowcarguy)
you shouldnt rule out anything if you dont know what's wrong, check everything even if you are sure its not the problem, you could be mistaken
Reebok4146
Honda Civic (2001 - 2005)
Aug 17, 2011 07:43 PM
amej8
18
Jan 26, 2011 06:27 AM
WRTEG
May 21, 2004 05:54 AM
Mag00n
Aug 29, 2003 12:54 PM
patastinky
Apr 19, 2003 02:43 PM
