Post your Compression ratio's and you compression readings.
Old Apr 24, 2003 | 08:37 AM
mrduque's Avatar
Default Post your Compression ratio's and you compression readings.
just taking a poll to see what kinda compression readings people get with different pistons.
Old Apr 24, 2003 | 09:22 AM
BabyDaddy's Avatar
Default Re: Post your Compression ratio's and you compression readings. (mrduque)
Pistons isn't the only thing that's gonna determine what your compression #'s are gonna be. You can run the same pistons in a motor and get higher compression psi than the same pistons in a motor with more aggressive cams due to the loss in dynamic compression from the cams. The info your asking for is useless.
Old Apr 24, 2003 | 10:17 AM
Black 2K's Avatar
Default Re: Post your Compression ratio's and you compression readings. (BabyDaddy)
http://www.c-speedracing.com/h...c.php
here you go...
Exeed
Apr 18, 2006 11:04 AM
rudebwoy
May 24, 2005 01:30 PM
94gsr18kid
10
Jan 25, 2005 05:35 PM
sushibug
Apr 3, 2002 05:04 PM
