Can someone give me a 4 wire o2 sensor pinout(p75)
Old Apr 24, 2003 | 08:24 AM
DEVIN22CBR's Avatar
Default Can someone give me a 4 wire o2 sensor pinout(p75)
I need to wire up a 02 sensor very fast guys. My gas milage is crap. If you could just give me the pin numbers or picture would be great. Thanks
Old Apr 24, 2003 | 11:25 AM
dfoxengr's Avatar
Default Re: Can someone give me a 4 wire o2 sensor pinout(p75) (BALL BAG)
what car, what engine harness are you using? and what motor?
Old Apr 24, 2003 | 12:27 PM
DEVIN22CBR's Avatar
Default Re: Can someone give me a 4 wire o2 sensor pinout(p75) (hybridvteceg)
93 b18a1 using 92 cx harness i belive and a 92 civic hatch cx ...
Old Apr 24, 2003 | 05:21 PM
dfoxengr's Avatar
ok dont wire to ecu...
this is what u do
white wire to white CX O2 sending wire
1 black to switched power, ie, when the key goes on, the power is on
other black and green together to ground and DONE...thats what i did on the same setup
Old Apr 25, 2003 | 10:29 AM
DEVIN22CBR's Avatar
where did you ground them ? Ecu ground or engine bay ground
Old Apr 25, 2003 | 12:54 PM
shermanyang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">ok dont wire to ecu...
this is what u do
other black and green together to ground and DONE...thats what i did on the same setup</TD></TR></TABLE>
Great info. but what i would like to know is which black one goes to the positive and which one goes to ground. or does it even matter??
Old Apr 25, 2003 | 08:07 PM
dfoxengr's Avatar
Default Re: Can someone give me a 4 wire o2 sensor pinout(p75) (shermanyang)
blacks dont matter, and all grounds in the car are the same...
Old May 14, 2003 | 05:35 PM
blackedoutcivic's Avatar
thanks
Old Oct 30, 2015 | 06:19 AM
EfB18's Avatar
this is what u do
How would i wire it to switched power ?
Old Oct 31, 2015 | 03:53 AM
HondaPartsHero's Avatar
Technical Hero
allmotor.net
Mar 8, 2007 04:10 PM
Slow96RedEk
Jun 1, 2003 10:17 AM
DEVIN22CBR
Apr 30, 2003 10:42 PM
monsta
13
May 1, 2002 01:03 PM
monsta
Apr 30, 2002 10:25 AM
