Idle is funny and check engine light comes on
Old Apr 24, 2003 | 07:15 AM
incognitoracerr's Avatar
Default Idle is funny and check engine light comes on
Ok so we milled the head on this baby, ported and polish and 3 angle valve job. Now we have some problems. The car lopes at idle which is normal because of the bigger cams we have...now the problem is...the car idles fine at start but then after a minute we get a check engine light to come on and the rpm climb up to 2500 and stay there...if you drive it for a while the rpm idle back down to normal but the check engine light stays on....we have everything on dead top center but timing is off by about 7 degrees...so the question is...how do we get it to proper timing, why does it idle so high up and the check engine light comes on?
Also can someone send me a link to where I can read the ecu check engine codes for this car...its a 1992 integra ls...thanks guys
gtec28
May 18, 2007 07:13 AM
dystro
Jan 30, 2006 11:22 AM
lanojp1
Nov 25, 2004 08:53 PM
cchev
Jan 23, 2004 04:00 PM
HybridGSR1
Oct 6, 2003 07:32 PM
