ls/vtec head gasket
Old Apr 24, 2003 | 07:05 AM
tegmaniac's Avatar
Default ls/vtec head gasket
I noticed when I lined up the b18a head gasket to the b16a head some of the passages were partially blocked. Is this normal? I saw that Mr. gasket makes them especially for the ls/vtecs. Does anyone have any experience with those and does it solve the problem with lining up the passages. Thank you
Old Apr 24, 2003 | 08:30 AM
Jeff C's Avatar
Default Re: ls/vtec head gasket (tegmaniac)
I just used am OEM one on my crvt. The partially blocked holes should not be a problem.
Old Apr 24, 2003 | 09:18 AM
sander's Avatar
2.7(p/t)
cometic gaskets are also very good, sold from endyn at the http://www.theoldone.com
there really shouldnt be any problem with your gasket. just make sure you put the gasket on the right way. make sure the stamped numbers on the gasket are on the lower left hand corner of the block.
Old Apr 24, 2003 | 11:20 AM
dfoxengr's Avatar
Default Re: ls/vtec head gasket (jazzyfoo)
use oem ls gasket and dont worry about nething else
krazych0p
Nov 10, 2008 01:38 PM
90Rexx
Feb 24, 2008 06:41 PM
eh2-hb
Oct 13, 2005 10:01 PM
ThirdGenLSR209
Jun 12, 2004 04:50 PM
S13 slide
Jan 4, 2002 06:20 PM
