5th Gear torque for '86-'87 Integ
I recently purchased an '86 Integra and need to replace both 5th gear main and countershaft 5th. I need to have a better idea of what to torque or gap the shaft nuts at. I've heard "torque the hell out of them" and "only torque them to 20lbs max." I know the former is incorrect because they were hardly torqued when I took them off (one was actually "free") but I would like to know what gap or torque wrench setting is correct.
thanks for any help you might be able to provide.
Alan
Austin, TX
Modified by DDIntegZguy at 2:55 PM 4/24/2003
Alan
Austin, TX
You are correct. Its not the gears that need to be torqued but the nuts that hold both 5th gear assemblies on. The nuts are 30mm and are smaller versions of the ones that hold the drive shafts on.
grinder_1
Transmission & Drivetrain
May 1, 2019 12:03 PM
RTW DC2R
Mar 8, 2013 05:35 AM
