B16A Parts???
Old Apr 23, 2003 | 10:10 PM
WindyIce's Avatar
Default B16A Parts???
If you were to get a B16A and you lived in the states. Where would you find all the JDM Mechanical Parts to fix it up. I'm assuming you just can't run into Auto Zone and pick them all up . OR can you? Where do you get all the parts?
Old Apr 23, 2003 | 10:16 PM
thaiphob's Avatar
Nikon!!!
Default Re: B16A Parts??? (WindyIce)
most parts can come off other B series cars like the B18c1 or c5 or the b16a2 or a3.
RCautoworks's Avatar
Here you go
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
***** Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets -8- 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol"
Old Apr 23, 2003 | 10:40 PM
SC0TT's Avatar
I used a lot of 99-00 Civic Si parts on my b16a1. Most all fit except distributor parts.
Old Apr 23, 2003 | 11:06 PM
EF-9SiR's Avatar
Default Re: (cr-tegra)
hey, i used parts off that list, they didnt all fit. the timing belt was short, so i had to get one from a 99-00 civic si, and the cap and rotor didnt fit from the list.
Old Apr 23, 2003 | 11:33 PM
eraser's Avatar
just fyi you guys.......99 si parts are cheaper than del sol parts at the dealer.......they may be the same thing........but ask for 99 si parts and youll get a better price
Old Apr 24, 2003 | 10:40 AM
Default Re: (EF-9SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF-9SiR &raquo;</TD></TR><TR><TD CLASS="quote">hey, i used parts off that list, they didnt all fit. the timing belt was short, so i had to get one from a 99-00 civic si, and the cap and rotor didnt fit from the list.</TD></TR></TABLE>
Sometimes they give you the sohc vtec del sol engine, I just save time and order it for a 00 si if the part is the same.
Old Apr 24, 2003 | 11:13 AM
raene's Avatar
Funny, I'm using an OEM del Sol VTEC belt and it fits fine... same with the distrib cap & rotor from the '90-'91 Integra PR3/PR4
Old Apr 24, 2003 | 11:35 AM
ScottEK's Avatar
Default Re: (raene)
I think with the whole timing belt of del sol vs. 00 si you just have to make sure to get both timing belt and water pump of the same kind. I went with the del sol vtec timing belt and water pump and everything fit perfect.
Old Apr 24, 2003 | 11:36 AM
raene's Avatar
Default Re: (beta13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote">I think with the whole timing belt of del sol vs. 00 si you just have to make sure to get both timing belt and water pump of the same kind. I went with the del sol vtec timing belt and water pump and everything fit perfect.</TD></TR></TABLE>
Interesting point, I believe you're right!
Old Apr 24, 2003 | 11:47 AM
Rywire's Avatar
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">Funny, I'm using an OEM del Sol VTEC belt and it fits fine... same with the distrib cap & rotor from the '90-'91 Integra PR3/PR4 </TD></TR></TABLE>
Same here. Ryan
PS, they must have gotten the sohc sol parts
Old Apr 24, 2003 | 11:49 AM
kanzenr91si's Avatar
Default Re: (raene)
you have to use those specific spark plugs? not 90-91 integra plugs?
Old Apr 24, 2003 | 12:11 PM
Malgerus's Avatar
Default Re: (kanzenr91si)
I use BKR6E-11 plugs, I believe.
Old Apr 24, 2003 | 12:55 PM
keebler65's Avatar
Default Re: (Mr. S)
i dont know if this is the same list, but heres two that i always use:
Maintenance Items:
Gaskets Head gasket = US '94+ DelSol VTEC
Valve cover gasket = US '94+ DelSol VTEC
Spark plug O-ring gaskets = US '94+ DelSol VTEC
Intake manifold gasket = US '94+ DelSol VTEC
Exhaust manifold gasket = US '90-7 Integra or US '94+ DelSol VTEC
Spark Plugs = Any US B series motor
Cap and Rotor = US '90 Integra
Spark Plug Wires = Any US B series
Thermostat = US '90-1 Integra, US '94+ DelSol VTEC, '99+ Civic Si
Timing Belt = US '94+ DelSol VTEC
Water Pump = US '94+ DelSol VTEC
Lower Radiator Hose = '91 Integra
Upper Radiator Hose = Universal, may need trimming
Alternator = '90 Integra
or 94 GSR alternator, which puts out 90 amps
Oil Pan = Any US B series
Oil Pump = 94 DelSol VTEC
Crank Pulley = Any US B series
Clutch = US '92 Integra GSR
Pressure Plate = US '92 Integra GSR
Pilot Bearing = Any US Civic/Integra
Throw-out Bearing = US '91-2 Integra, P/N 22810-ps1-015 $47.05
Flywheel = Any US B series
Axles = http://www.raxles.com, can use others, but best solution.
Intermediate Shaft = US '94+ DelSol VTEC
Mounts = http://www.hasport.com
Shift Linkages = http://www.hasport.com
Headers = best to use JDM B16
ANOTHER LIST:
Water Pump 19200-P30-003 94 - del sol $86.28
Head Gasket 12251-P30-014 94 - del sol $57.56
Oil Control Orfice O ring 15142-PH3-003 94 - del sol $1.36
Intake Manifold Gasket 17105-P30-004 94 - del sol $8.26
Exhaust Manifold Gasket 18115-P30-013 94 - del sol $11.30
throttle Body Gasket 16176-PR3-010 90-91 integra $4.71
Pcv valve 17130-PM6-G01 94 - del sol $11.98
Timing Belt 14400-PR3-004 94 - del sol $48.72
Alternator Belt 31110-PR3-003 94 - del sol $7.56
Tensioner 14510-P30-003 94 - del sol $50.94
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same) $11.69
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same) $2.76
Cap & Rotor Assembly 06303-PR4-000 90-91 integra $24.54
Rotor (If needed seperately) 30103-PR3-016 90-91 integra $6.87
Clutch Cable 22910-SK7-A02 90-91 integra $45.54
Throttle Cable 17910-SK7-A03 90-91 integra $17.18
Cam Seals (2) 91213-PR3-004 94 - del sol $8.52
Oil pan seal 11251-P30-004 94 - del sol $18.64
Oil Filter 15400-POH-305 94 - del sol $4.93
Shift linkage bushing 54303-SB2-010 90-91 integra $4.66
crank seal 91212-PR3-003 94 - del sol $5.78
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same) $12.00
Valve cover grommets (8) 90442-P30-000 94 - del sol $20.80
Spark Plug O rings (4) 12342-P66-000 94 - del sol $7.16
Rubber plug for exhaust cam tranny side 94 - del sol $4.00
Spark Plugs (4) BKR6E-N11 NGK $8.00
Upper Radiator Hose 19501-PR3-000 92 - integra gsr $14.71
Lower Radiator Hose 19502-PR4-A00 90-91 integra FREE BY MISTAKE
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol $5.62
Washer for coolant drain on block 90401-PR4-000 94 - del sol $3.00
90 LS dizzy w/ leg cut off
Old Apr 24, 2003 | 01:16 PM
gringo7718's Avatar
Default Re: (keebler65)
where are those prices from?
Old Apr 24, 2003 | 01:43 PM
REDBARON's Avatar
Default Re: (gringo7718)
They look like the dealer price. Some differ, depending on what dealership you go to.
Old Apr 24, 2003 | 08:47 PM
WindyIce's Avatar
Default Thanx
THan alot guys It really helps me out.
Old Nov 16, 2015 | 05:42 AM
Jonathan91891's Avatar
Hey guys I need a little help I need a head gasket b18a1 bottom end and pr3 head should be a b16 gasket do you guys know the part number for it ?
civichopeful
Jul 22, 2003 10:54 PM
SeaBass
May 31, 2003 03:48 PM
91hatchnewb
Apr 28, 2003 01:54 PM
bluecrxsi
22
Feb 25, 2003 04:47 PM
Monty
Sep 7, 2002 05:41 AM
