Help! starter problem?
Old Apr 23, 2003 | 10:01 PM
RayRay602's Avatar
Default Help! starter problem?
I have a 99 Civic that has a good battery, good ground with full electrical power. When I turn the ignition past the 3rd click to crank the engine, the starter clicks once and then everything dies? It seems to reset itself and the power comes back after a given time or after i connect and reconnect the battery. Is it my starter? I don't have an ignition kill, why is it killing the power?
Old Apr 25, 2003 | 10:49 AM
PnX-R's Avatar
Default Re: Help! starter problem? (RayRay602)
Seems almost like the Starter is draining the Battery.. But I can't tell.. More info would be nice though..
Old Apr 28, 2003 | 02:45 PM
RayRay602's Avatar
Default Re: Help! starter problem? (PnX-R)
I found the problem. Can you believe it, it was a bad battery cable. It's wierd because the wire is making contact on both ends but yet the power flow wasn't constant. Well either way, it's much better than a bad starter. Thanx for your input PnX-R.
mdrouillard1983
Jun 6, 2014 05:24 PM
miked123
Jun 27, 2013 04:44 AM
homegr0wn
May 15, 2012 05:47 AM
dizzlebB
May 25, 2011 11:37 AM
sparxx
Jan 6, 2004 02:46 AM
