please help
I have a 91 crx with a b16. If i go faster than 10 mph the drivers side tire like hops or does something.
I broke the axle and the intermedate shaft. When they broke it riped a hole in the back of the block. I can only bolt 2 out of the 3 bolts to the block. I replaced the axle and the intermedate shaft. But it doesn't still work. any suggestions
thank you
thank you
2 of the 3 bolts? which bolts are you talking about? not entirely sure if i understand what you're saying, but if there is a hole in your block that might be the reason it doesn't run....
chriscool888
Jan 9, 2011 09:54 PM
MIGPA26
11
Feb 20, 2010 01:17 PM
HONDA RR
May 4, 2007 08:15 AM
MeanGreenEG9
Jan 13, 2003 08:17 AM
