How long does it take to let piston rings set
Old Apr 23, 2003 | 04:04 PM
loclowd's Avatar
Default How long does it take to let piston rings set
I am sick of hearing **** if you know what I mean, what do you recommend me doing, I just got my engine fully balanced and blueprinted, and now I have ls pistons and an 11:5:1 compression....thanks yo
Old Apr 23, 2003 | 04:19 PM
DJ_SaNdOz's Avatar
Default Re: How long does it take to let piston rings set (dee-ecks)
http://mototuneusa.com/break_in_secrets.htm
Old Apr 23, 2003 | 04:32 PM
loclowd's Avatar
Default Re: How long does it take to let piston rings set (dj_sandoz)
Hell yea man, does that apply to only bikes...anyone?
Old Apr 23, 2003 | 04:40 PM
joey1320's Avatar
i'm also interested in this topic, i have heard so many different theories...
anyone???
Old Apr 23, 2003 | 06:30 PM
USDM 4G VTEC's Avatar
i let my rings rest for the first 1000 miles..... when i rebuilded my Z6....
after 1000 miles u can then punish it IMO
Old Apr 23, 2003 | 06:53 PM
sporkcrx's Avatar
Default Re: How long does it take to let piston rings set (USDM 4G VTEC)
I think after I rebuild my a6 I'm going to barely break it in since some people think it's a myth...I'll find out how it fares.
Old Apr 23, 2003 | 06:55 PM
sslude's Avatar
Default Re: How long does it take to let piston rings set (sporkcrx)
1000 miles of slow (low rpm) driving
Old Apr 23, 2003 | 07:39 PM
MONSTERZC's Avatar
Default Re: How long does it take to let piston rings set (sslude)
500-1000 miles is good
Old Apr 23, 2003 | 08:03 PM
altoid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj_sandoz &raquo;</TD></TR><TR><TD CLASS="quote">http://mototuneusa.com/break_in_secrets.htm </TD></TR></TABLE>
i believe that man is a retard. He says that the small amout of pressure exerted on the cylinder walls couldn't possibly hold all that force of combustion. The two forces are completely perpendicular so they don't even act on each other. So there could be 1 billionth of a pound of pressure exerted on the walls and it would still properly seal. sure the rings are there for other purposes too, but he seems retarded to me.
Old Apr 23, 2003 | 08:14 PM
Josh717's Avatar
Default Re: How long does it take to let piston rings set (altoid)
I ride motocross, in my 125 I put the new top end, piston, ring, wrist pin, and break it in for 15 min. Then I hit around 11,500 rpm. This is a 2 stroke, with ports, not valves. If my .125l motor can handle those kinda rpms, im sure your car will be fine. However, I would suggest running it for a hundred miles to make sure everything is running fine.
Old Apr 23, 2003 | 09:04 PM
wrXtian's Avatar
i'd be hesitant to do that immediately after installation on a car.
Old Apr 23, 2003 | 10:15 PM
Louie B.'s Avatar
Default Re: How long does it take to let piston rings set (AllMotorCRX90)
I'm impatient.... I stayed below 4000 rpm for about 200 mi, 5000 rpm until 500 mi, then started thrashing it!!! I just hit 2000 mi today and it seems to be doing well.
best advice: follow the recommendations of the company that are supplying the parts, they're the ones that have to stand behind them when they fail.
also think of this, most professional racers start running their engines hard right away. Have you ever seen John Force baby his funny car around the streets for 1000 mi before tearing down the track at 300 mph?
That may not be an apples to apples comparison....
Old Apr 23, 2003 | 11:17 PM
Just Checking In's Avatar
Default Re: How long does it take to let piston rings set (thumpu77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumpu77 &raquo;</TD></TR><TR><TD CLASS="quote">That may not be an apples to apples comparison....</TD></TR></TABLE>
and that, would be correct.
Old Apr 24, 2003 | 05:02 AM
slowassgsxr750's Avatar
Default Re: How long does it take to let piston rings set (Just Checking In)
race cars dont break in there motor,seem to be fine,i broke in my b16 on the dyno,201 to the wheels all motor
Old Apr 24, 2003 | 08:40 AM
cruicked's Avatar
everything is set once you fire up the engine. Break in, Shmake in.
Old Apr 24, 2003 | 09:41 AM
loclowd's Avatar
Default Re: (cruicked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cruicked &raquo;</TD></TR><TR><TD CLASS="quote">everything is set once you fire up the engine. Break in, Shmake in.</TD></TR></TABLE>
Ur first post, Lol, i think I will break it in junior I am going to do about 300 miles of driving , then gradually kick into it once in a good while, I'lll post up and let everyone know how it goes. Thanks
Old Apr 24, 2003 | 10:05 AM
Steve91's Avatar
I run a new motor for about 30mins, then drive it around the block. Change the oil, then beat on it. A blueprinted and balanced engine does not need any special break in.
Old Apr 24, 2003 | 12:17 PM
4drEF's Avatar
Keyboard Humorist
Default Re: How long does it take to let piston rings set (Steve91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve91 &raquo;</TD></TR><TR><TD CLASS="quote">I run a new motor for about 30mins, then drive it around the block. Change the oil, then beat on it. A blueprinted and balanced engine does not need any special break in.</TD></TR></TABLE>
Ok - piston ring seat in a very short time. This probably happens in less than 100 miles.
That's not what a complete 1500 mile break in is all about though. You also need to let the rings and cylinder walls works themselves in for long term effects. After the rings seat properly they wear and grind down to fit the individual cylinder walls so you minimize blow by and crap like that. a properly broken in engine WILL have a little more power than the same engine that is not broken in right.
If you take a motor out and run for 100 miles and then start abusing it, you will probably see the effects of high speed glazing. This is where some oil passes by the ring and burns to the cylinder walls. this burnt up oil becomes much too slick for the rings to work properly and you will essentially be burning oil for the rest of the life of the engine. The rings won't do their job.
If you don't vary the speeds and you keep the rpm at too low of a level then you won't wear in the rings enough. The rings will never see the proper ammount of compression required to wear them in and mate them to the cylinder walls. This can lead to bad rings and blow by = less power.
So - they say to vary your engine rpm. This is because you will doubtfully have the perfect rpm at any time. So varying the rpm will see low rpm and higher rpm (I don't mean 10k rpm... that's WAY to high for proper wear) and you get the best of both worlds.
Old Apr 24, 2003 | 02:40 PM
loclowd's Avatar
Default Re: How long does it take to let piston rings set (4drEF)
WErd thankx a lot for all these responses, u all are very helpful
allmotorcrx2001
Oct 16, 2006 02:33 PM
the g2 teg
Apr 25, 2006 01:30 PM
douglas_be
Mar 29, 2004 01:31 PM
zer0zer0 TypeR
Sep 4, 2003 11:35 AM
craigmk2crx
Jul 15, 2002 02:43 AM
