Where do I check the clutch fluid?
I'm finding myself retarded and not knowing where to check my clutch fluid to see if it's ok. Somebody please help the idiot. Thank you
The clutch fluid resevior is on the drivers side toward the rear of the engine bay. You will see two resevoirs, the large one is for the brakes but the smaller one is the clutch resevoir.
ok, that's a big duh, now how do i know if it's good or bad? heh
i figure if it's really dark then it's bad.
Thanks again
Thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssAcura »</TD></TR><TR><TD CLASS="quote">... now how do i know if it's good or bad? heh
i figure if it's really dark then it's bad...</TD></TR></TABLE>
It needs to be filled somewhere between the min & max lines on the reservoir. If it's more than 2 years old, change it by bleeding your clutch. Flush enough fluid thru so it's all fresh.
Same thing for your brake fluid.
SoullessJapaneseMachine
Oct 2, 2009 09:26 AM
hondapwr
19
Dec 21, 2007 06:16 PM
Qwikrex
Apr 20, 2003 03:27 PM
