hooking up vacum lines for hf ctx to skunk2 intake manifold on b18c
Old Apr 23, 2003 | 12:34 PM
HT Chaplain's Avatar
Loved
Default hooking up vacum lines for hf crx to skunk2 intake manifold on b18c
I need help identifying vacum lines. I bought a Haynes manual and it doesnt have the vacum diagram that i need so im looking for everyones help. i have 4 vacum hoses coming from my car and i only need two that go to the manifold. one is for the EVAP and one is for the fuel pressure regulator. and i assume i just plug the other 2. i would appreciate you help because i plan on doing the swap this weekend. The 4 vacum lines im talking about come from the firewall with the charcoal canister and map sensor are located. thanks everone.
Modified by legutki at 9:50 PM 4/23/2003
Modified by legutki at 9:51 PM 4/23/2003
Old Apr 24, 2003 | 06:48 AM
Loved
Default Re: hooking up vacum lines for hf crx to skunk2 intake manifold on b18c (legutki)
bump
Old Apr 24, 2003 | 07:23 AM
Jonathan_ED3's Avatar
from your cannister, the very top nipple, it should say 'purge' on it...that goes to the EVAP sensor
the other one (should be right under the one I was just talking about) from the cannister should go somewhere right above the throttle body.
I don't know about the other two lines you're talking about..most of the cannisters I've seen usually on have 3 lines, and one of those just goes back down to it's own thing.
Old Apr 24, 2003 | 10:52 AM
Loved
Default Re: hooking up vacum lines for hf crx to skunk2 intake manifold on b18c (hot_EG)
The other 2 are not on the canister but on the firewall next to the map sensor combo there a black box that covers this and they pug into the stock im. any suggestions on what to tee and what to plug anybody
Old Apr 24, 2003 | 12:17 PM
hmmm...I'm not exactly sure what you're trying to explain
Can you get a picture up?
LUKE 92 GS-R
Jun 18, 2008 06:17 PM
juanchoenuncrx
Dec 26, 2007 05:03 PM
Hondamonster
Jun 9, 2007 04:35 AM
Bumnah
11
Jul 8, 2003 06:20 PM
