how do you remove a g3 oil pan
Old Apr 23, 2003 | 12:21 PM
Loveless's Avatar
Default how do you remove a g3 oil pan
I have searched for this but did not find anything.
Old Apr 23, 2003 | 12:37 PM
E-Rok's Avatar
EPIC TUNING
Default Re: how do you remove a g3 oil pan (Loveless)
1st you have to take off the lower flywheel cover, its blocking a few of the oil pan bolts, get under the car and youll spot ir right away. after you get that off, its just alot of 12mm bolts (or is it 10mm? i forgot), and it comes right off. pretty straightfoward, takes about 30 minutes tops.
Old Apr 23, 2003 | 12:38 PM
Loveless's Avatar
Default Re: how do you remove a g3 oil pan (rewsnaeht)
any photos?
by the way, should I expect oil pouring down on me?
Old Apr 23, 2003 | 12:42 PM
E-Rok's Avatar
EPIC TUNING
if you drain the oil 1st (which you need to), you wont get much oil on you, just keep the pan tilter towards the drain plug.
Old Apr 23, 2003 | 01:25 PM
Loveless's Avatar
cool, my buddy told me to ask if I need to replace any gasket or any filter?
Old Apr 23, 2003 | 01:54 PM
Anyotherone's Avatar
Make sure you only torque the bolts on the oil pan hand tight... as a matter of fact... not that tight at all. Otherwise, the gasket will crimp, and you'll have oil dripping out like I did.
Old Apr 23, 2003 | 02:00 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: how do you remove a g3 oil pan (C_tech97GSR)
The exhaust manifold has to come off first. Then remove the engine stiffeners (if you have them, B18C1 engines do) and then the flywheel cover. Drain the oil, then remove the bolts and nuts (10 of one and 8 of the other, I think). Use a new gasket, and tighten the bolts to the exact factory specs. I don't know off-hand what the specs are, but it's not very much. Make sure they are all torqued evenly so you don't warp the pan or the gasket.
Old Apr 23, 2003 | 02:09 PM
Loveless's Avatar
Default Re: how do you remove a g3 oil pan (PatrickGSR94)
so there is no filter, right?
Old Apr 23, 2003 | 02:19 PM
Fuuma0083's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_tech97GSR &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you only torque the bolts on the oil pan hand tight... as a matter of fact... not that tight at all. Otherwise, the gasket will crimp, and you'll have oil dripping out like I did. </TD></TR></TABLE>
Old Apr 23, 2003 | 02:20 PM
ragejed's Avatar
Dude..get a beam torque wrench. I did, i torqued them as it said in my helms. No leaks yet. Been like 6k.
Old Apr 23, 2003 | 02:24 PM
Default Re: how do you remove a g3 oil pan (ragejed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">
Dude..get a beam torque wrench. I did, i torqued them as it said in my helms. No leaks yet. Been like 6k.</TD></TR></TABLE>
Word.
That's what I used the second time around. The first time a friend of mine was helping me do the install. I had the helms manual but he still torqued them too much.
Old Apr 23, 2003 | 02:28 PM
Loveless's Avatar
i been looking at craftman's 3/8 torque wrench, that's good enough?
Old Apr 23, 2003 | 03:41 PM
ragejed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">i been looking at craftman's 3/8 torque wrench, that's good enough?</TD></TR></TABLE>
Tis what I use for 3/8
Old Apr 23, 2003 | 04:19 PM
Loveless's Avatar
my buddy said there might be a mesh inside to hold the sludge down, now if the pen is in pieces, some of it might be stuck there too.
can someone confirm the existance of this mesh? if so, what is it called?
Old Apr 23, 2003 | 04:33 PM
ragejed's Avatar
Ur buddy...hhehehehehehe
Anyway, no mesh dude. and you better hope there isnt sludge in ur car.. heh
Old Apr 23, 2003 | 04:57 PM
Loveless's Avatar
it's a different guy who caused my misfortune. on me for letting the *** ever come close to my car.
Anyways my buddy isn't sure and just told me to check so I guess there isn't a mesh like he thought.
thanks guys
lazyxmofo
Mar 9, 2011 06:26 PM
civicSF98
Jul 20, 2009 09:24 AM
wdissident
Jan 19, 2009 08:49 PM
AF-b16a1
Aug 2, 2004 09:53 PM
02 coupe
Jun 25, 2003 01:56 PM
