Canadian R goes to Dyno
Old Jun 29, 2001 | 02:40 PM
raw01's Avatar
New User
Default Canadian R goes to Dyno
Took my 2001 r to dyno. Dynojet 248 c. The following are corrected numbers.
Stock timing all belts in place... 169.9 and 121.3
Stock timing minus pwr str...... 173.1 and 123.1
Approx. 20 degrees timing...... 173.9 and 122.5
Approx. 19 degrees timing...... 174.3 and 123.0
These numbers are with only 4500 kms on the car.
Also took car to ST.Thomas dragway.
Stock... best time.... 14.533 @ 96.74 Added AEM a week later....
AEM..... Best time.... 14.369 @ 98.46 Much warmer and more humid this time.
Will post new dyno #'s with AEM in the next week or so. Any comments???
Old Jun 29, 2001 | 02:47 PM
 The Snipe-R's Avatar
New User
Default Re: Canadian R goes to Dyno (raw01)
Sweet, looks like you got one of the 'strong' ones!
Your numbers are really impressive for such low mileage.
Old Jun 29, 2001 | 03:36 PM
RagingAngel's Avatar
Default Re: Canadian R goes to Dyno (Super*)
agreed!
that is some great times....!!
keep it running strong!
Old Jun 29, 2001 | 04:49 PM
R748's Avatar
Impressive, can you post your stock dyno chart? It might be interesting to see how the power characteristics differ. That is, does the torque stay on longer? Does it peak higher but fall later? Obviously, your torque figure is quite a bit higher that most ITRs I've seen so far. My best stock torque is around 117.3 (which resulted in around 164HP), this is for a 98.
Old Jun 29, 2001 | 04:54 PM
raw01's Avatar
New User
Default Re: Canadian R goes to Dyno (R748)
If someone out there can show how to do it, I'll put it up know problem.
Old Jun 29, 2001 | 05:34 PM
AWDSOME's Avatar
Those are some damn good dyno numbers and great 1/4 mile times. Looks like I am going to have to advance my timing. As sad as it may be, I already drive without my AC and PS belts. I am testing to see if I can live without the AC and I have just been too lazy to put the power steering belt back in since the last time I was at the dragway.
jmal1919
Jun 1, 2005 12:39 PM
Opie
Jan 15, 2004 01:37 AM
EagleR
Jul 1, 2002 01:22 PM
fso_BamBam
Mar 23, 2002 09:42 PM
MintyDip
Oct 25, 2001 06:40 PM
