J's racing engine dampner
Old Apr 23, 2003 | 09:22 AM
Josh02Si's Avatar
Default J's racing engine dampner
Anyone have this? With my stock tires wheel hop wasnt really a problem in my EP3 beucase they didnt get any traction at all it was all wheel spin. Now that I got my volks and my paradas I get wheel hop if i try and launch. You guys try out the engine dampner I am just owndering if it is worth the money and if you guys have any feelings on it!!! Thanks
Old Apr 23, 2003 | 12:12 PM
todaCspec's Avatar
Default Re: J's racing engine dampner (Josh02Si)
Alot of members from ClubRSX say it elimantes wheel hop completely, even w/bigger wheels.
Old Apr 23, 2003 | 01:22 PM
1abSi's Avatar
they JUST got the shipment out for the EP3...plus for 30-40 you can get the es motor mount inserts and use the 150 you save for something else
Old Apr 23, 2003 | 03:25 PM
spoondc5's Avatar
Default Re: J's racing engine dampner (1abSi)
Works great dude... problem is if you can find it in stock although you can always get some engine mount inserts from energy suspension
Old Apr 23, 2003 | 03:48 PM
T.Slick's Avatar
Should hopefully have mine by the end of the week. http://www.polepositionproducts.com
Let you know what I think when I get it installed.
Old Apr 23, 2003 | 09:19 PM
epthree's Avatar
Default Re: J's racing engine dampner (T.Slick)
i plan on doing this mod myself. I want to eliminate the wheel hop but i dont want the vibrations that mount inserts give.
Old Apr 24, 2003 | 07:01 AM
Josh02Si's Avatar
Default Re: J's racing engine dampner (spoondc5)
Ya I could get those mount inserts but those are a pain in the *** to put in. Plus the Js racing dampner is adjustable so you could save yoruself from vibration when you want to drive comfortably then stiffen it up when you are at the track or whatever
Old Apr 24, 2003 | 08:33 AM
lube's Avatar
No the J's is NOT adjustable. I have one on my type-S and I love it. You can actually tell the car is running when you're at a stop light. Slight vibration in the cabin, but it's not bad at all. Definitely a worthwile mod.
Old Apr 24, 2003 | 08:41 AM
Josh02Si's Avatar
Default Re: J's racing engine dampner (lube)
Sorry for some reason I thought it was a djustable but anyywa.... Where did you get yours at most poeple have them out of stock?
Old Apr 24, 2003 | 09:04 AM
chunky's Avatar
Default Re: J's racing engine dampner (epthree)
i've always been a fan of eliminating the cause of the problem instead of trying to cover the symptoms of the problem.
The ES motor mount inserts are really not all that bad - if you bump the idle from 750rpm to 1000rpm, you will feel zero additional vibration.
and for the money, the j's damper isn't worth it when the real solution to the problem can be had for under 30 bucks (i paid 28 shipped).
Old Apr 24, 2003 | 09:37 AM
fireant's Avatar
Default Re: J's racing engine dampner (chunky)
So has anyone figured out how to bump the idle up?
Old Apr 24, 2003 | 10:28 AM
lube's Avatar
Well to me, it seems like raising your idle is also trying to cover the symptons of a problem. Plus it only took maybe 20min to put the J's on, whereas the ES mounts take all day. Oh, and the J's looks good too
Old Apr 24, 2003 | 10:34 AM
Josh02Si's Avatar
Any pics of it installed?
Old Apr 24, 2003 | 12:04 PM
BlairSpeed's Avatar
could someone explain the difference between engine mounts and engine dampners? which ones are easier to install / cheaper?
Old Apr 24, 2003 | 01:49 PM
Josh02Si's Avatar
Default Re: (BlairSpeed)
The mount inserts are anywhere betwen 30-40 bucks and they are a bitch to put in. YOu are looking at a good day or so of labor getitng those things mounted in. The engine dampner is about 200 bucks but its a straight forward install that'll probaly take you about 15 minutes are so. Suppsively from peoples responses they both work well.
I still would really like to see some pics with the dampner installed on a EP3. thanks
Also where did you guys get yours? Its a hard little peice to find let me know!
Nooch
20
Jun 30, 2010 05:05 AM
The Weather Man
Jan 22, 2006 10:07 PM
NeVeR bLoWn
19
Mar 11, 2004 01:21 PM
JustChou
Sep 28, 2002 06:21 PM
khang77642
Jun 20, 2002 05:06 PM
