Rear main seal replacement, h22a1?
This a common failure?
I found a descent amount of oil on the tranny/bell housing on the bottom as well as some surrounding parts, I tend to lose more oil than I should too yet no blue clouds or signs of excessive consumption...
clutch doesn't seem damaged (yet) if the rear main is indeed leaking
yep, happens quite often. The rubber becomes old and starts leaking. It's good to change that seal when you replace the clutch.
pentaq
pentaq
just to thow this in here i have a 5th gen and the oil pan gasket a small rubber piece is right by the bell housing and could fail and make you think it is the rear main
just a suggestion but i bet it is the rear main
deeboi
Jan 21, 2013 10:25 PM
CivicTuneR95
Jan 13, 2003 10:17 AM
