track times with my newly done b16 swap
Old Apr 23, 2003 | 06:20 AM
ViperRedCRX's Avatar
Default track times with my newly done b16 swap
completly stock, even left the clutch in it that was in it when i got the swap. (slipped it's *** off)
14.9@95
2.5 60' (due to street tires, and slipping stock clutch)
does this sound about right?
Old Apr 23, 2003 | 06:59 AM
b16_madman's Avatar
Default Re: track times with my newly done b16 swap (ViperRedCRX)
you got me beat...
look at my sig.
Old Apr 23, 2003 | 07:02 AM
slowpokesi's Avatar
how the **** did u pull that time with a 2.5 60 ft?
i pull 15.2 with a 2.3
Old Apr 23, 2003 | 07:20 AM
Default Re: track times with my newly done b16 swap (slowpokesi)
what was your mph on your 15.2 run?
Old Apr 23, 2003 | 07:25 AM
raene's Avatar
Not bad!
Old Apr 23, 2003 | 08:12 AM
NiMhist's Avatar
Default Re: track times with my newly done b16 swap (raene)
Pretty nice time, thats about what I'm hoping for in mine. Are you using the crx's stock exaust and intake?
Old Apr 23, 2003 | 08:19 AM
Default Re: track times with my newly done b16 swap (NiMhist)
stock everything...just running itr intake manifold (going turbo, so did it while it was out)
slowpokesi's Avatar
93 mph
Old Apr 23, 2003 | 08:49 AM
wuhungsixxx's Avatar
New User
sounds a lot better than other EFs with the same swap and the first time at the track...
haha sounds like my first run....but i have a B18C... to you
Old Apr 23, 2003 | 08:56 AM
REDBARON's Avatar
You got me beat also.
60' = 2.335
1/4 = 15.139
MPH= 91.28
But this was my first time at the track with the swap. I'm sure I'll break into the 14's next time I go.
Old Apr 23, 2003 | 01:35 PM
Noahk's Avatar
Default Re: track times with my newly done b16 swap (REDBARON)
What car is the motor in? I'm going to guess a 88-89 hf or 88 si or dx.
Old Apr 23, 2003 | 02:10 PM
Bases's Avatar
Hell yeah that's good
Old Apr 23, 2003 | 02:23 PM
nitekidsef9's Avatar
Default Re: track times with my newly done b16 swap (EK9Grander)
ok i guess my time was better then i thought...........14.5 stock b16 with exh in a 91 dx h/b but i also only weigh 126 pounds :D
Old Apr 23, 2003 | 02:35 PM
mycvc8u2's Avatar
good job-that's how mine was when i first did it. the best mod i did was my ctr cams and lightweight flywheel. put me into the 13's with all the boltons.. (hint-hint)
Old Apr 24, 2003 | 06:30 AM
Default Re: track times with my newly done b16 swap (mycvc8u2)
it's in a 88 si. i'm not very happy with it. was hoping for a 14.5 or so. i pulled a d16z out that ran a 14.6, but it had every bolton under the sun on it.
no ctr cams or anything here. i need boost.
nsxmatt
Nov 8, 2004 11:01 PM
97mini-me
Sep 28, 2004 07:18 PM
Rob!
75
Jul 8, 2004 05:49 PM
nsxmatt
Apr 16, 2004 05:58 PM
sleepin91teg
Jan 18, 2004 07:29 AM
