How Much/Where to get the plug for the GM 3 Bar Map Sensor
Old Apr 23, 2003 | 04:06 AM
95c1v1cs1's Avatar
Default How Much/Where to get the plug for the GM 3 Bar Map Sensor
I just ordered my 3 bar Map sensor and I realized that it prolly doesn't come with a plug for it. Where do you get those. And how much do they cost.
Thanks-
Corey
Old Apr 23, 2003 | 04:15 AM
ekb18c's Avatar
Default Re: How Much/Where to get the plug for the GM 3 Bar Map Sensor (95c1v1cs1)
pep boys, rs straus, any local automotive store.
Range from 1.50 - 3.00
Old Apr 23, 2003 | 06:49 AM
95c1v1cs1's Avatar
Default Re: How Much/Where to get the plug for the GM 3 Bar Map Sensor (ekb18c)
Does it come from a specfic car?
Old May 1, 2003 | 08:36 AM
95c1v1cs1's Avatar
Does anyone have a part number for this.
Thanks
Old May 1, 2003 | 09:17 AM
accordfreak's Avatar
i just pulled one off from the junk yard... they usually cost 10 bucks in stores
Old May 1, 2003 | 10:14 AM
intekragsr's Avatar
Default Re: How Much/Where to get the plug for the GM 3 Bar Map Sensor (accordfreak)
GM AC Pressure switch plug was used (Conduct Tite part number 85146 from Pep Boys, about $10)
courtesy of hondata.com
Old May 1, 2003 | 11:15 AM
servion's Avatar
Default Re: How Much/Where to get the plug for the GM 3 Bar Map Sensor (intekragsr)
Where did you guys get the 3bar map sensor?
Old May 1, 2003 | 11:22 AM
DaveF's Avatar
Default Re: How Much/Where to get the plug for the GM 3 Bar Map Sensor (servion)
i am almost sure you can purchase them at a gm dealer or you can also get them from precision turbo
Old May 1, 2003 | 11:30 AM
g2turbo's Avatar
Default Re: How Much/Where to get the plug for the GM 3 Bar Map Sensor (2.2Lcivic)
Send a PM to "gitwidit"
he is the parts manager at Holman GM in Cincinnati.
I bought both the sensor and pigtail from him
Old May 1, 2003 | 01:30 PM
BoostedSi's Avatar
Default Re: How Much/Where to get the plug for the GM 3 Bar Map Sensor (g2turbo)
the plugs are about 10 at pepboys. I couldnt find that part number at pepboys so i bought a tps sensor plug for a gm at autozone. I modded it a little to work...it was pretty easy tho.
Old May 7, 2003 | 09:41 PM
95c1v1cs1's Avatar
Default Re: How Much/Where to get the plug for the GM 3 Bar Map Sensor (BoostedSi)
I couldn't find the part at Pepboys... Anyway, I just got the map Sensor, how the hell does that bolt up to your throttle body... The holes for the screws are way further apart than stock.
Here is the part number that i got... 12223861
Old May 7, 2003 | 09:57 PM
MotorMatrix.com's Avatar
I am a bad person
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95c1v1cs1 &raquo;</TD></TR><TR><TD CLASS="quote">I couldn't find the part at Pepboys... Anyway, I just got the map Sensor, how the hell does that bolt up to your throttle body... The holes for the screws are way further apart than stock.
it doesnt bolt up. you either leave the stock one on or plug it. then you mount the map sensor as close to the intake manifold as possible and run a vacuum line to the intake manifold.
Old May 7, 2003 | 10:04 PM
CzanSOHC's Avatar
Default Re: How Much/Where to get the plug for the GM 3 Bar Map Sensor (MotorMatrix.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com &raquo;</TD></TR><TR><TD CLASS="quote">
it doesnt bolt up. you either leave the stock one on or plug it. then you mount the map sensor as close to the intake manifold as possible and run a vacuum line to the intake manifold.</TD></TR></TABLE>
Old May 7, 2003 | 10:27 PM
95c1v1cs1's Avatar
Default Re: How Much/Where to get the plug for the GM 3 Bar Map Sensor (CzanSOHC)
I did a search and understand now. Thanks guys.
has anyone Hard wired their sensor up or do you find plugs?
Old May 8, 2003 | 11:25 PM
pissedoffsol's Avatar
25 Year Member
bump... anyone have pics of how they mounted the 3 bar? i didn't even notice they were different sizes...
anyone plug theirs? im going to have to, as i don't have a stock map sensor right now, and buying one as a plug is kinda stupid
so yeah, pics r00&gt;&lt;0rs
XxRoCkMaNxNEOxX
Sep 15, 2013 01:43 PM
oksblue
Mar 31, 2013 03:59 PM
E39Boost
Mar 26, 2013 10:39 AM
*Boostwerks*
May 9, 2004 01:30 AM
Type-ARR
Jul 7, 2003 02:58 PM
