car not starting!
Old Apr 22, 2003 | 10:02 PM
After_Burner's Avatar
Default car not starting!
hey guys, last friday, i took about a 7hour drive across the province, and i stopped twice during the whole time, and each time it was for gas, once i filled up on gas, i go to start the car but it wouldnt! :<.. i had to wait about 10-15mins before i could go again, any reasons for my car to misbehave like that?? oh! and I would have averaged about 70mph!!
any help would be appreciated guys..
thanx
Old Apr 22, 2003 | 10:19 PM
89_LXi's Avatar
Default Re: car not starting! (After_Burner)
What year is it? Sounds like the characteristics if a main relay gone bad (that usually only happens when it's hot though). Is the starter cranking it and it doesn't fire up? Or just click click? I've heard of ECU's going bad on some of the newer Hondas as well.
Sorry I can't be of more help. Main relay was the only thing that ever caused mine not to start on the first crank, and that would happen after filling up with gas and such.
Old Apr 22, 2003 | 10:29 PM
Brandon's Avatar
Life is Suffering
Default Re: car not starting! (89_LXi)
Is there a thud and the starter doesn't crank? If so, you need to replace the contacts on the starter.
Old Apr 22, 2003 | 10:45 PM
holy **** u guys r brainchilds! (pardon my french)
my car is a 97 but with an H22 swap from 99...its 4doors and after i fill up on gas, it DOES NOT! go click click, i mean, it does crank, but i donno! :<..
ironic thing is that Ive done this road trip before and its never happened?? the exact same one!
Old Apr 23, 2003 | 06:31 AM
JimBlake's Avatar
So it cranks but doesn't start... Check to see if it has spark (next time it happens). Coil or ICM inside distributor can get flaky when they get hot. After a long highway run, when you stop for gas your engine compartment gets much hotter than it was while you're driving. Once it cools off your ICM starts working again. Trouble is, once you open your hood & pull a wire to check for spark, it's already cooled down some.
In case it's your main relay, listen for the fuel pump to prime itself by running for a second or 2 when you first turn the key on, before you crank the starter. It's kind of quiet, so you might have to open the gas cap to listen.
Old Apr 23, 2003 | 12:06 PM
Default Re: car not starting! (JimBlake)
ok, fair enough, but i dont really wanna deal with it when it happens!!..
i wanna fix the prob now, and i dont wanna take it to any mechanic cause they'll charge an arm and a leg out here!! :<...
Old Apr 24, 2003 | 04:24 AM
JimBlake's Avatar
The mechanic will have the same trouble. He won't know what it is until it screws up while he's watching.
Old Apr 24, 2003 | 12:45 PM
hmmm..ok, thanx man!
i appreciate the help! :>
cooleyhigh12
Dec 10, 2012 07:01 PM
stevew84
25
Jul 17, 2008 06:16 AM
kieron
Jun 19, 2004 02:59 AM
turboxsi
Jan 29, 2004 09:06 AM
